Anybody know the front spring rate code on 1994 Ford Bronco's
JimMartin
Suwanee, GA.
Does anybody know the spring rate code on my 1994 Ford Bronco front springs? Tag on them says F4TA 5310-JA?
The part number for that is
Part #
F4TZ 5310 B
I could not find the spring rate.
What is your goal? Going with custom springs?
Want something stiffer?
Want lift?
Want softer ride?
J
JimMartin
Suwanee, GA.
Front of my 94 Bronco is swaging pretty bad. Both front wheels are lending in at the top. So I need to replace the springs. Thinking about putting in Moog 820's? I've used Moog 824's before in my other Bronco, but they are like putting in leveling springs. Just looking for an OEM replacement spring.
Yo Jim,
From my 1996 Bronco/F Series Workshop Manual, partial @ http://www.diesel-dave.com/vehic/manual/stj/stjleft.htm
Moog brand coils are very good!
See Section;
Section 04-00: Suspension, Service
1996 F-150, F-250, F-350, F-Super Duty and Bronco Workshop Manual​
DIAGNOSIS AND TESTING
Inspection and Verification​
And see
And inspect Spring and Shock Bracket,etc
I have used the moog 820s I thought the variable rate made them ride pretty nice.
Always hard to compare to factory if they are better or the same as factory ride since we are replacing worn or broken ones.
