1995 Eddie Bauer from Las Vegas
milan65
Hello, my name is Milan and I live in Las Vegas, NV and this is my Bronco:
1995 Ford Bronco Eddie Bauer specs:
Engine:
1998 Cummins 4BTA
  • P7100 Injection pump advanced timing
  • #10 Fuel plate
  • 3K RPM springs
  • 0.35 Fuel delivery valves
  • Replaced all gaskets in 2018
  • Fluidampr Diesel Damper For 1998.5-2002 Dodge Cummins 5.9L 24V; 960301
  • Jet-Hot Ceramic Coating - headers and turbo
  • ARP Head Studs
  • SBC GM Flywheel Adapter
  • GENUINE HOLSET HX30W 44MM
  • Vacuum and power steering pump combo from 6BT
  • Zerex G-05 coolant
  • Frozen Boost Aftercooler with Bosh pump
Transmission: NV4500 GM 1st gen
Transfer Case: Ford NP 205
Front Axle: 1997 F150 Dana 44 - 4.11
Axle ends F250 Dana 44 1986 8 lugs
ARB Locker – RD116
Driveshaft by Tom Wood’s
Rear Axle
: 1996 Ford E 250 Dana 60 – 4.11
Dana 60 Rear - 35 Spline
YG D60-411 [24060]
ARB Locker RD167
Other:
  • Odyssey battery 65-PC1750T x2
  • RedArc battery isolator SBI212D
  • Hydroboost brakes - Ford Mustang brake booster
  • Deaver rear leaf springs
  • Shackle flip
  • Fiberwerx Hood, Dash and central console
Shaggy
Administrator
Arizona
Engine:
1998 Cummins 4BTA
  • #10 Fuel plate
  • 3K RPM springs
  • ARP Head Studs
ARB Locker – RD116
Rear Axle
YG D60-411 [24060]
ARB Locker RD167
Other:
  • Shackle flip
Thanks for posting your first post Milan. Only took you 7 years! Ha ha!
Is this your daily driver?
yo Milan,
Welcome to you and your well modified 95!
ASAP, find out if speed control recall work, if equipped was completed. If you still have concerns about Recalls, please contact the Ford Customer Relationship Center:
1995 Bronco Dealer Brochure @ 1995 Ford Bronco
1995 Bronco Drivetrain, Powertrain Service Manual - Google Drive
1995 Bronco Chassis, Service Manual - Google Drive
To switch between folder list & grid views, click the button to the right of the "DOWNLOAD ALL" button in the upper right corner of the window) by HawkDriver
Haynes Red Manual for 80-95 Bronco & F Series @ Hanes guide 80-96 bko f series.pdf via BroncMom
