1996 Bronco XLT 5.8 Won't start.
Bronco Billy R
West Tennessee
Come home from work, she just died in the road. The engine turns over but won't start up. I was thinking fuel pump,  but before I get to deep I want some advice. Could it be a relay, module or the shut off switch?
Yo Billy,
WELCOME!
I assume it cranks over well, if not let us know.
If it's a 78 Bronco, see https://jalopnik.com/heres-how-you-diagnose-an-engine-that-wont-start-1717491831
But if efi equipped, see https://troubleshootmyvehicle.com/ford/4.9L-5.0L-5.8L/how-to-troubleshoot-a-no-start-1
Best bet is that you have a mom and pop parts store that you use and they can loan you tools such as spark or fuel pressure test, etc.  I prefer mom and pop stores over AZ, etc because they usually have better maintained stuff.
Bronco Billy R
Bronco Billy R
West Tennessee
Thanks so much for the quick reply,  that's awesome.
Sorry, it would help if I told you what I'm driving.  1996 5.8 xlt. Cranks over good just won't start.
I checked a couple of things. I can hear the fuel pump come on when I turn on the key. The shut off switch is in the correct position. I Haven't had a chance to check the spark yet, Or to see if it is getting fuel, that's my next test.
What's your advice if there is no spark?
Yo Billy,
YW!
For no spark, you'll  that site's troubleshooting within the efi link I posted,
Here it is https://troubleshootmyvehicle.com/ford/4.9L-5.0L-5.8L/how-to-troubleshoot-a-no-start-1
Then you'll see https://troubleshootmyvehicle.com/ford/4.9L-5.0L-5.8L/how-to-troubleshoot-a-no-start-2
Was speed control, if equipped, recall work completed by a dealership? Call local dealer or register and view status @ https://owner.ford.com; or @ https://vinrcl.safercar.gov/vin/ ...  have VIN ready.
"Summary: ON CERTAIN PICKUP TRUCKS, PASSENGER VEHICLES, SPORT UTILITY VEHICLES, AND MOTOR HOMES CHASSIS, THE SPEED CONTROL DEACTIVATION SWITCH MAY, UNDER CERTAIN CONDITIONS, LEAK INTERNALLY AND THEN OVERHEAT, SMOKE, OR BURN. THIS COULD RESULT IN AN UNDERHOOD FIRE."
To confirm3 current status, use this guide by jowens1126 @ https://www.fullsizebronco.com/forum/23-technical-write-ups/457065-93-94-96-cruise-control-recalls-repair.html#post6530073
Note that the 93 recall is different than the 94-96 recall
96 Bronco-F-Series Workshop Manual (PARTIAL) via 1996 Bronco/F-Series Workshop Manual
96 Bronco Owner's Guide, Maintenance Schedules  & Parts and Accessories by Ford @ https://www.fleet.ford.com/partsandservice/owner-manuals/
96 Bronco Dealer Brochure @ https://www.supermotors.net/registry/3549/15947-2  ... scroll down
96 Bronco Quick Tips Brochure Excerpts & some Eddie Bauer options @ http://www.supermotors.net/registry/2742/80431-2
Free registration for some wiring diagrams (partial, 86 through 96) and Technical Service Bulletins, (80 through 96) same as by Ford @ BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
Register to see most Ford dealer maintenance/repairs done @ any dealership nation-wide @ http://owner.ford.com .
Zl
Bronco Billy R
Bronco Billy R
West Tennessee
Ok. Tracked it down to my  Ignition control module. Replaces it and it cranked up fine. Last night come home it sputtered once pretty bad. Any ideas on that?
Yo Billy,
Is check engine light on while it sputters?
Yo should try to borrow an OBD II scan to obtain codes.  Some parts stores will loan you one using their loan a tool program.
➡️Was dielectric grease spread on ICM HEAT SINK?
Bronco Billy R
Bronco Billy R
West Tennessee
Oh yeah,  I spread all over it. it hasn't acted up scene then. Maybe it was just a fluke. I removed the cats earlier this year and installed true duals. Of course my cel is always on. I tried the eliminator the o2 sensor with no luck. Have you heard of anyone using a diode on the o2 sensor to trick the computer? What about high flow cats? I really want to get that cel off.
Yo Billy,
Most go to high flow cats and have no codes nor CEL Lit.
Some who guess they suggest removing the CEL bulb, but that won't pass emissions test, where done.
Try Walker Exhaust @ https://www.walkerexhaust.com/find-my-part.html
1996 Ford Bronco  Engine - 5.8 Liter V8 EPA-COMPLIANT CONVERTERS
Front
FEDERAL EMISS. MODELS.; FEDERAL/EPA CONVERTERS ARE NOT LEGAL FOR SALE IN THE STATE OF CALIFORNIA. RESTRICTIONS MAY APPLY IN OTHER STATES. CONSULT YOUR STATE?S REGULATION PERTAINING TO AFTERMARKET REPLACEMENT CONVERTERS PRIOR TO INSTALLATION; EXHAUST GASKET IS RECOMMENDED
N/A
STANDARD DIRECT FIT
FITS FED. & CALIF. EMISS. MODELS.; FEDERAL/EPA CONVERTERS ARE NOT LEGAL FOR SALE IN THE STATE OF CALIFORNIA. RESTRICTIONS MAY APPLY IN OTHER STATES. CONSULT YOUR STATE`S REGULATION PERTAINING TO AFTERMARKET REPLACEMENT CONVERTERS PRIOR TO INSTALLATION; MODIFICATIONS AND/OR ADDITIONAL PARTS REQUIRED.
FRONT
ULTRA UNIVERSAL
FITS FED. & CALIF. EMISS. MODELS.; FEDERAL/EPA CONVERTERS ARE NOT LEGAL FOR SALE IN THE STATE OF CALIFORNIA. RESTRICTIONS MAY APPLY IN OTHER STATES. CONSULT YOUR STATE?S REGULATION PERTAINING TO AFTERMARKET REPLACEMENT CONVERTERS PRIOR TO INSTALLATION; MODIFICATIONS AND/OR ADDITIONAL PARTS REQUIRED.
REAR
ULTRA UNIVERSAL
Bronco Billy R
Bronco Billy R
West Tennessee
I'm in west Tennessee, here emission code are not required. Since I have true dual exhaust, shouldn't I be able to get by with just one cat? I only have one down stream o2 sensor. If so, I assume the high flow cat will go between the upstream and downstream sensors on that one side (which is the driver side). I'm grateful for your wisdom and advice. Thanks for making this site available.
Juan3774
Dayton Ohio
I had that happen to my 96 2 yrs ago it was my fuel pump, when you turn the key on before you crank with driver door open you should hear the pump energize for a second or 2 if you don't hear it, it's your pump
