electrical
jcain1998
i need some help on where to start looking for problem. my dash gauges work sometimes then quit. different gauges at different times. also i have had to replace the starter, alternater and battery all in the last year and having some other electrical issues. could there be one problem or short causing all of my electrical issues or am i looking for more than one problem?
Yes, check along where cables rub on surfaces, near the manifold, etc. I'd also suggest removing, cleaning and reinstalling all grounding locations, ie. Battery cable connections light grounds, etc. one of the main grounds is under the dash against the fire wall near the driver side.
yo, As Fred Advised!
Also,
G200 (BK/W) in Gauges Wiring Diagram in a 92
Source: by Chilton http://content.chiltonsonline.com/content/images/WD/Ford/177/WD_Ford_177541.pdf
see Splice S216
G200 Behind bottom of RH cowl panel Location Diagram (partial) in 92-96
Check Fuse 17 to ensure it is seated
Check Connector C251 @ cluster to ensure it is seated
Source: by fordbronco1995 ("JUICE")
See Splice S215 in Main harness 14401, near T/O to C251
Ground G200 Lug shown in Instrument Panel Wiring, Gasoline Engines
see # 30 Wiring to Ground
Diagram is from behind dash, so Lug is on passenger side
(Part of 14401)
