CAI advice
Bronco Noob
Hey guys, this is my first time starting a topic, so here it goes. :blush:/> I was doing some research on CAI and wanted to get a K&N; but, they are extremely over priced for me. I was looking on Ebay the other day and found a CAI that I have never heard of before. The brand is Insys-USA. Does anybody know or have one of these puppies? How do they sound? Do they help with HP at all? Here is the link to the one I was looking at...
http://www.ebay.com/itm/FORD-F150-BRONCO-XL-XLT-5-0-5-0L-5-8-5-8L-V8-AIR-INTAKE-1988-1993-1994-1995-BLUE-/281003696898?fits=Model:Bronco|Year:1992&hash=item416d202302&item=281003696898&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
PS: I have a 1992 5.0L. And looking for some more umph ;)/>/>/>
90bronco86
deltona Florida
ive never even heard of that brand, and the cold air intake systems really dont give enough benifit to justify the price, i have a buddy that paid 300 for the k & n kit and there is almost no difference between our trucks and i only paid 20 for a spectre re useable filter.
yo Bronco Noob,
As 90 advised and I agree because Ford has a good cold air sys in-place already, but upgrade filter
Intake Temperature Comparison Tests, Stock Air Box vs. K&N® FIPK & Insulated K&N® Replacement Filter in a Centurion 460; miesk5 Note, Results are Comparable to Tests in other Ford Engines
Source: by FOUR WHEELER Magazines Project M.P.G. via performanceunlimited at http://www.performanceunlimited.com/projectmpg/airtemp.html
AIR CLEANER COMPARISON at http://www.performanceunlimited.com/projectmpg/aircleaner.html
see other tests there
and to improve existing, consider;
Insulation Installation in a 95 5.8; Reflectix® - insulation, avail @ Lowes. etc.; Double Reflective Insulation ST16025 - 16" x 25' feet
Source: by exclamation_mark at http://www.supermotors.net/registry/21848/79085
Insulation Installation Info & pics in a 95 5.8; Shurtape Technologies® - avail @ Lowes. etc., DC 181 Class 1 Flex Duct tape, UL 181B-FX Listed. Available in black or metalized silver printed OPP film in 120 yard rolls; "...You can see the insulation between the pipes. Tape wouldnt hold it to the outside and around the box. The bottom of the box is wrapped in insulation, and here you can see the room for the bolt holes..."
Source: by Jtegg008 (Armageddon Ready) at http://www.supermotors.net/registry/23521/77373
Insulation Installation pic in a 92
Source: by Waterhorse at http://www.supermotors.net/registry/media/913991
Bronco Noob
Bronco Noob
yo Bronco Noob,
AIR CLEANER COMPARISON at http://www.performanceunlimited.com/projectmpg/aircleaner.html'>http://www.performanceunlimited.com/projectmpg/aircleaner.html
Thanks 90bronco86 for the input, much appreciated! So, miesk5 if i am reading that correctly http://www.performanceunlimited.com/projectmpg/aircleaner.html says that the K&N CAI air filter was the only thing replaced and it gave the best results? And you are saying that I should wrap my tubes in insulation; and sorry, I have to riddle your guys' brain, I don't know anyone personally who knows this much about broncos :p/>/>
Also, doesn't an after market CAI "let the truck breath better" by opening up that tiny hole so the the air can get sucked in faster?
Rons beast
Hey Noob,
CAIs are by theory suposed to increase horsepower 2 ways.
First, they are supposed to allow the engine to "breathe" more. This they do very well. Problem is that the advantage is realized at Wide Open Throttle. Unless you run your truck at the drag strip, you won't notice much benefit.
Second , as the name implies the intake is supposed to draw in cold air. (colder air is denser...denser air = more air in the combustion chamber....more air ...more BOOM= more power.)
This they do poorly. Many of the products are actually drawing in underhood air that is warmer than that outside of the vehicle.
As M5 suggested, replace the stock air filter with a good high flow unit. Then insulate the airbox and the supply ducting to keep the engine heat from transfering.
Doing this you should notice some better power. Nothing that will make the Bronc pound the earth, but it should be something you notice.
I have attached a pic of my home made insulated airbox. I had just the K&N filter and the original box was discarded by the P.O. When I built the insulated box and ductwork to draw in outside cold air i noticed more power and a little better gas mileage.
Good Luck
Bronco Noob
Bronco Noob
Hey Noob,
Good Luck
Thanks mate, I was wondering how/why CAI were recommended! On a side note, you also recommend insulating the tubes with insulation?
90bronco86
deltona Florida
now my truck is missing the part of the air box that goes from the grill to the airbox its self, would this make a big difference in power n gas mileage?
Similar threads
T
Replies
Views
1K
Top stories on BroncoZone.com
T
T
Replies
Views
1K
T
T
Replies
Views
927
T
T
Replies
Views
2K
T
T
Replies
Views
789
T
mindy
