Shock mount stud
stevel
I was installing 2" coil spring spaceers on my 96 Bronco, and one of the forward lower shock mout studs broke off when trying to tighten the nut back down. How do I replace this stud?
koontreeguy
western mass
gonna be a pain in the a55. jack up ur rig and put on jack stands and let the suspension hang. gotta remove the coil springs and the coil spring stud and the stud on the opposite side of the coil stud pointing towards the ground. they're gonna be tough because they're torqued to 250-300 ft/lb I believe. might want to unbolt the radius arm also to aid in putting everything back together. the bracket that the forward shock mount is on should slide out and replace with a new one. might be easier to weld the old stud on or just run 2 shocks in the front.
S
stevel
the stud that broke is the forward one of a dual shock set up. So it's the shock that mounts forward of the coil sproing and axle. Looks like it's pressed into a plate.
koontreeguy
western mass
that's what I'm sayzin- that whole plate comes off like I described, assuming it's the same as an 86. anyone know if they made the dual front mounts the same ?
S
stevel
Ok, I miss read it the first time. Great, that does sound like a real pain. No way to put another stud on that plate, huh?
koontreeguy
western mass
it's not the biggest pain and it is a good learning experience I guess. definitely doable in a day. if it were me I'd just run 2 shocks up front an keep the other 2 for spares :) /emoticons/smile@2x.png 2x" width="20" height="20" /> good luck guy !!
Check out Miesk5's Homepage of Bronco links for info on that lower-front shock stud. It's pressed in from the back side, and not easily replaced as stated. If you are able to weld, a better design is to replace the single stud with a standard rear shock mount lower breacket for more support. If I find some thing in more detail, I'll post it up, JSM84
http://fullsizebronco.com/forum/showthread.php?t=17765
The main idea is to box in the lower mount to accept a bolt thru two sides instead of a sinlge stud.
bobstrat
beautiful trenton, n.j.
pull the wheel off. grind shock mount flush to bracket. if you have access to a torch, poke a hole through the broken mount, ream with a drill and install bolt on replacement from napa.
if you don't have access to a torch it takes a little more drill work.
i had the same problem with mine,
here it is with replacement installed:
shock mount
S
stevel
for some reason I can't open the last link. I'd really like to see the bolt on replacement from NAPA. Do you remember the part number and cost>
bobstrat
i don't remember the part number, but it was not a ford specific part. it was less than $20. i'll see if i can dig up the part #.
