4.6 DOHC into Bronco
Flyinmechanic
Hello all, new on this forum! Parting out my 97 Mark VIII LSC. any kits or advice on swapping the 4.6 DOHC 32V into early Bronco's? I have the transmission, computers, etc. Guess an F150 x-fer case from a 4.6 would be needed, any advice?
Thanks; Doug
bigbluebronc
ca
Thanks; Doug
Kinda sounds like you know what your doing, I have no knowledge of swap kits... I say fit motor trans and transcase together then slip it in and built mounts too fit then order up new drive shafts or shorten or lengthen then tell us how smart you are and tell us how too do it!!!Good luck sounds like a smart refit
BBB
Dont forget your efi fuel tank, efi fuel pumps, gears ,lockers, tires, beadlocks, upgraded brakes(gotta have those for all that power)....This could be costly.
