Hellp! Intermittent Wiper switch?
brad050
Hey my wipers do not go back to off position and the Intermittent has no delay... I just replaced my wiper switch to try to fix this problem and it didn't help? what kind of wiring problem could this be?
Krafty
Ontario Canada
with an intermittent wipers there is the switch and a relay before the motor, regular wipers have a different switch and no relay. find a different relay from the wreckers and see if that fixes it
Krafty
Ontario Canada
a malfunction in the motor usually means that the wipers won't move. but have you tried swapping out your intermittent relay between the switch and motor?
Did you ever have intermittent? Some trucks didn't come with intermittent. If so you will need to find one in a junkyard or go to Jeff's Bronco graveyard and order switch and intermittent unit. As far as parking the wiper blades goes, that is a function built into the motor. diagram attached
no.1 with interval timer
no.2 without interval timer
brad050
So I need to replace the motor to get it to go back to off position... correct?
Ricky B
So Cal and Baja
Check the connections for corrosion first.
On my '87, I found that the short black ground wire that comes out of the switch box casing to the dash grounding ***** was stiff, fragile and almost broken off the case itself. Was a 15 minute fix after I had diagnosed the problem (but no, I didn't try to solder the wire to the case--I just mixed up some JB Weld and then taped the crap out of it)
Good luck....
Bronc094
