fornt axle dosent engage
wakko101
des moines ia
i shift into 4high or low the indicator light comes on but front axle will not engage i got underneath and both drive shafts seem to be working correctly. could i possibly have blown lockouts? was told when i bought it that 4 wheel didnt work and wasnt sure why any help woulb be greatly appreciated. i went out and bought some warn units to replace them with is that a good choice? thanks again.
50joe
Trenton NJ
Would help to know what were working with, but I'm assuming it still has the automatic hubs? It's possible they are sticking, (which is a common problem). Try putting it in 4 wheel, and while it's on the ground, try to turn the front drive shaft. If it spins, its in the case or actuator. If not, jack up the front end, (still in 4x4), and turn the front wheels by hand. If the hubs are locking, you'll see the shafts to the wheels turn. If the tire spinns freely, may be time to rebuild/replace the front hubs. And yes, the warn's work great. I have them, and even though one is partially damaged due to a past bearing issue, they haven't failed me yet.
Devil Dog08
philadelphia pa
i agree with you mr **** . i was having the same problem . i had auto hubs i replaced the with warn .problem solved
ThouBeezy
wakko, let me know if that was your problem. i am too having the same problem with my 88 bronco. the 4x shifter moves nice and smooth, but nothing locking in high or low.
thanks
Ricky B
So Cal and Baja
thanks
You have a manual stick for your t-case? Or push-button?..........
fred tyler
