turing lights
bigchris2005
ok i have a 96 ford bronco with a 302. the problem i am having right now it the turning lights not working at all i have running, brake, and hazard lights but no turning lights. i have check all the bulbs change the fuses,i just change the switch tonight still not working now i am at a lost. so i need some help.
thanks
None are working... front or back? If so, I'd suspect the flasher. Its probably in or near the under the dash fuse box.
bigchris2005
well i havent given that a thought because the hazards lights are working i myself cant see the hazards working and not the turn signal. that is why i havent given it any thought as far as the flasher.
also they are not working both front and back. but like i said before the hazzards light do work all around i havent check for a bad ground yet or anything like that. i might be a day or 2 befor i get a chance to do it i live here in northern indiana we it is a tid bit cold out right now with snow. so since i dont have a nice place to put it inside and work on it it will be a couple of days
bigchris2005
also they are not working both front and back. but like i said before the hazzards light do work all around i havent check for a bad ground yet or anything like that. i might be a day or 2 before i get a chance to do it i live here in northern indiana we it is a tid bit cold out right now with snow. so since i dont have a nice place to put it inside and work on it it will be a couple of days
bigchris2005
kc.collins21
