sudden death..activated alarm?
sharpe21
My uncle has a 95 ford. It was working fine this morning, but all of a sudden, the truck wouldnt start. He then disconnected the battery and cleaned the little knobs on top of it with a silver thing. When he tried to start the car it made a chirp sound, but almost started and after that, the alarm began to start. We looked at the fuse and tried the corresponding one and others too..everything but that didnt help. Every time he connected the battery, the alarm would go off. How do we stop this? =\
50joe
Trenton NJ
Depends on the Alarm. Most of them have a button under the dash somewhere that requires you to turn the key on, and hold it for thirty seconds, turning into sleep mode. If you no longer want the system, take off the under covers, and find the box. (its 90% of the time blatently obvious), start cutting the wires that run from the alarm module to the factory harness. Then reconnect the wires that were put in by ford with solder or a good heat shrink connector, and forget it ever existed. Anyone with any knowldedge of cars can bypass those stupid things in less than 10 seconds, so get rid of it. Its more trouble than its worth.
50joe,
Thanks for the tip, I have had the same issue with mine, crappy connections, and the truck wouldn't start. Pulled the cables to clean them and then the alarm was set, and it wouldn't start. I had to move it, so I jumped 12 volts to the trigger of the fender mounted starter relay, all the while the alarm was blaring. The truck started, I moved it, and then disconected the battery until I came back with the alarm remote (two days later) and wouldn't you know... the battery to the remote was dead! Urrgh!!! When I put a fresh battery in the remote, and turned off the alarm everything was back to normal, but now I make sure that I bring the set of keys that has that big remote attached to them when I will be using the bronco.
Mine has a push button AND a switch. Neither my son, nor I were ever able to figure it out, no wthat you say hold it for 30 seconds, I am sure that we never did that, so perhaps I'll try that today if it isn't too cold out. DO you have any idea what the switch is for? My alarm has the remote start too, that's actually a nice feature.
yo gang.
Post up the Alarm's MFGR/model # etc..from Key FOB or on Alarm Module Body (not the horn)
Guessing that da Switch is what is ref. to as da Valet / Override Switch; "...Many of today's alarms have a port to plug the valet/ override switch(es) directly into them. If not connect one wire of the switch(es) to ground and the other to the specified input of the alarm..."
by the12volt.com
& by the12volt.com; they also state; "...If you do not find the vehicle wiring information you're looking for here, please post your request at the12volt's install bay. We will NOT respond to any requests by email. * Cruise control and navigation information such as Tach, Vehicle Speed Signal (VSS), and Brake wiring can often be found in the alarm information available. Please see alarm information for remote start and keyless entry wiring..."
1995 Ford Bronco (fullsize) Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+ Yellow Ignition Switch Harness
Starter Red/Light Blue Ignition Switch Harness
Ignition Red/Light Green Ignition Switch Harness
Accessory Gray/Yellow Ignition Switch Harness (Blue/Green for Heat/AC)
Tach Tan/Yellow Coil
Neutral Safety Wire Not Grounding OEM Switch opens Starter Circuit
Brake Switch Light Green Brake Switch
Trunk Pin n/a Works with Dome Light
Parking Lights Brown (+) Light Switch
Head Lamp Red/Yellow (+) Light Switch
Hood Pin n/a
Factory Disarm Dark Green/Purple (-) Driver's Kick Panel
Door Trigger Black/Light Blue (+) Driver's Kick Panel
Door Lock Pink/Yellow Passenger's Kick w/Keyless Negative Trigger w/o Keyless
Door Unlock Pink/Light Green Reverse Polarity use Driver's Switch to Test
Horn Wire Yellow/Blue (-) Steering Column
Windows Up LF=White/Black, RF=White/Yellow
Windows Down LF=Yellow, RF=Tan/Light Blue
http://www.the12volt.com/installbay/alarmdetail/807.html
I did compare the sit'e radio/spkr wiring info & it matched what I have for same year Bronco that I have, so I can assume the above is close/correcto mongo
the12volt.com alsohas a lot of basic info & a few Alarm Type Forums; you may get lucky there
Will Post this for now so I can see Joe's Bronco Year since I can't see the info in Reply Mode.
1989-91 Ford Bronco (fullsize) Alarm/Remote Start
1989-91 Ford Bronco (fullsize) Alarm, Remote Starter, Keyless Entry Wiring Information
Brake Switch Red/Green Brake Switch
Parking Lights Brown (+) Light Switch Harness or Driver's Kick Panel
Hood Pin n/a
Factory Disarm n/a
Door Trigger Black/Light Blue (+) Driver's Pin Switch
Door Lock Black/Orange Driver's Kick Panel
Windows Up LF=Red, RF=White/Yellow,
Windows Down LF=White/Black, RF=Tan/Light Blue
sharpe;
I believe the thAng your uncle cleaned was the battery's posts.
Ask him to inspect the cables carefully, to the starter relay on passenger fender, and to the starter, etc.
Look for whitish deposits on the connectors, as well as the cable strands; due to the age of these Broncos, corrosion sets-in under the connectors, and between the cable's strands.
Also, this is a C&P from my 96's Owner's Guide;
Remote entry personal alarm
If you wish to activate the remote entry system
personal alarm, press the PANIC button. This
will honk the horn and flash the lights for
123
approximately 2 minutes 45 seconds. You can
turn it OFF by pressing the PANIC button again
from the same transmitter or by turning the
ignition to the ON or ACCESSORY position.
When you use the remote entry UNLOCK or
PANIC buttons, the illuminated entry system
turns on the vehicle’s interior lights for 25
seconds. You can turn these lights off with the
remote entry LOCK button or by turning the
Illuminated Entry System (If equipped)
This system will provide illumination of the
vehicle’s interior courtesy lamps when either
outside front door handle is pulled or when the
Remote Entry System is used to unlock the door
or sound the Personal Alarm. The system will
automatically turn off after approximately 25
seconds or when the ignition is turned to the
START or ACCESSORY position.
NOTE: The inside lights will not turn off if
you have turned them on with the
dimmer **** or if any door is open.
Battery Saver (with Remote Entry — If
equipped)
When the ignition is turned off, the vehicle will
turn off battery voltage to all of these lights after
40 minutes: glove box, engine compartment,
overhead console, mirror, courtesy and
interior (including cargo) lamps.
This will prevent draining of the battery if these
lights have been left on inadvertently or if a
door is not completely closed. Battery voltage to
these lamps will be restored when the remote
entry transmitter is used, any door is opened, or
the ignition key is turned on again
Thanks miesk5 for that info, I think I'll print it out and put it with my EVTM.
On my FOB I have:
FCC ID.ELVNTREA
PART NO. 5BCRO3B
I have both a switch, and a button on the driver's side kick panel.
I set the alarm with my FOB.
I turned the ignition key to ON and held the button in for 30-40 seconds, and then I tried to start, but the starter didn't crank (no clcik of the starter relay)
I flipped the switch and did the same, and got the same results.
So... I tried one more test, I put the key in acc position, held the button for 30 or so seconds, then tried to start, to no avail.
Am I doing something wrong?
I used the FOB to turn the alarm off, and she started right up.
ok,
I have no idea of what is wrong.
But a fast Google job gives;
Code Alarm 2-Way Replacement
Remote Code Alarm CA-680/180 or Audiovox Replacement Transmitter
FCC ID# ELVNTREA
next is da Search for Audiovox corp site
http://mobile.audiovox.com/audiovox/AudiovoxController.do?ACTION_TYPE_ID=ACTION_TYPE_CATEGORY&ACTION_CATEGORY_ID=STR_CATEGORY_CODEALARM
I picked this one out: look for what you have (if it is still sold and supported; if not, look @ one that is similar..# of buttons, etc.)
http://mobile.audiovox.com/audiovox/AudiovoxProductDetail.do?ACTION_TYPE_ID=ACTION_TYPE_PRODUCT_DETAIL&ACTION_CATEGORY_ID=STR_CATEGORY_CODEALARM_SECURITY_SYSTEMS&ACTION_PRODUCT_ID=CA1050
Owner/User Manual http://audiovox2.info/docs/voxx_mob/man/CA1050_DOC_OM.PDF
Will post now since you're here and my Comcast is very very slow
50joe
Trenton NJ
All of those are different. Alot of them are turn the key on and hold the button, or flip the switch, some are hitting the buttons a few times, and there are a few more I havent even figured out yet. They drive me nuts sometimes. Worst thing about them is, most of the time when they go off, people just ignore them anyway since they go off all the time. Myself included.
muddrivermike
Texas Arp
Hey Steve,dont you like when these idiots bring their vehicles in with the sensitivity cranked up on them,and every time a breeze comes by they go off?Thats why NOW I just keep the key on and hope it starts with out a boost pack after Im done the service.Thats why those ones cranked up we call a camden alarm.Cause those are the people that we get that have them all the time. <):)
50joe
Trenton NJ
If i cant get them to shut off, I cut the wires to the damn siren. Then those stupid lights can blink all day long for what I care. LOL
kc.collins21
