33" tires and 6" lift?
bsamc2000
Johnstown
Has anyone added a 6" left with 33" tires? I am getting ready to get new tires and I was looking at getting 33" BF Goodrich Mud-Terrain KM. I know I will need a lift but I am un-decised on a 3" or a 6" lift. I'm thinking a 6" would be better because it gives me more options in the future.
Does anyone have any pictures of either of these? This would be very helpful.
Thank you,
Brian
50joe
Trenton NJ
My 305/70/16's come out to roughly the same size as a 33, and I have no lift. There is a spacer behind the front bumper, and I get some rub on the radius arms when cutting the wheel real hard, but other than that, its fine.
Miss Kitten
alberta canada
if you want to put a 6" lift on you can easily fit 35's if you're wanting to keep just 33's on the truck then you should be able to fit them stock
if you want a little bit of lift and the 33's you can look into a body lift
cars
i installed 39's on my 67 with only a 4" lift. works great. it had 35's with a 2" before. i would not go over a 2" because of the pinion angle. also buy the bushing kit for the front end to change the pinion angle.
MUZZALL
Ellensburg WA
My 94 with a 6" lift looked good with my 35-12.5 bfg's on it, looked goofy with my 33-10.5 winter tires on it. Some kits have the same brackets for 4" and 6" lift (my pro-comp kit did). You just use different coils and bolt locations. A kit like this may be a good choice or just go with 35's or 36's now.
89purple horse
colorado
Thank you,
Brian
i have a 6 inch rough country lift on my 89 with 33 12.50 and i dont have any clearences issues. i agree with muzz with the 6 inch kit and little 33's looks kinda goofy if i had it to do over again i would go with 35's
famousguy_fsas
THE BRONC
Ya I have 33 on my stock 86. And works fine. I'm actually doing the same thing and am swaying to the 35 tire myself. But on the same subject does anyone know how ill do with 35 tires and stock 355 gears? Or should I just wait till I can afford the 456s
honesthat
