Flat rear tire and the steering is everywhere
I_LOVE_MY_BRONCO
Bristol RI
I have Mickey Thompson Baja Belted Tires and they are huge (35in high by 17 wide). Is there anything I can do to seal the leak (its is where the tire meets the rim). I cannot find these tires anywhere online. Anyone know where I can find a new one if it is unrepairable???
Also, where can I get a well priced jack? My Bronco's frame is about 27inches off the ground.
And with all the lift the steering wheel has to be held pretty deep to the right to go straight. And all the time I am getting a lot off play in the steering wheel.
Krafty
Ontario Canada
if its in the bead of the tire and rim as long as its not a crack , tear or piece missing, if you break the bead, clean up both the tire and inside of the rim, then slap a bunch of bead sealer paste on it it should hold air.
as far as your steering it depends on A. year of bronco B, type/ height of lift, C. the condition of steering joints. and radius arm brackets.
also, have you gotten an alignment done on it since the lift? or even just recently?
I
I_LOVE_MY_BRONCO
Bristol RI
she's a 1992, and I have a 3 inch body and 6 inch suspension lift. I'm going to check all that out, I can't thank you enough for the info
