Front Shock Tower
Para
1996 Bronco with Dual Shocks, replacing rotted drivers side front shock tower
Any idea what the STOCK bolts held the shock and spring tower in place?
It looks like I am looking at a domed-head carriage bolt that should have a nut on the back side
I run my hand across the back side of the frame rail and feel nothing
Either the bolt is totally rotted off or the frame was tapped for a thread
Im guessing its thru bolt, but I just want to check
Check with local dealer parts dept. for 7/16" grade 8 bolt plus nut and washer.
Or at Ace, etc.
1980-1996 Ford Bronco and F-Series Hardware Kit, Coil Spring Tower
http://shop.broncograveyard.com/1980-1996-Ford-Bronco-and-F-Series-Hardware-Kit-Coil-Spring-Tower/productinfo/33213/
Confirm with sales dept.
See Diagram @ http://www.diesel-dave.com/vehic/manual/stj/stj41b01.htm
For some unknown reason, our site rejects some diagrams
Popping/Creaking TSB 97-03-10 for 80-96 BRONCO, F-150, F-250 LD 1980-97 F-250 HD, F-350 1988-97 F SUPER DUTY, F-47 by Ford @ http://www.thedieselstop.com/faq/9497faq/tsb/tsb/files/970310.pdf
See (F) Spring Towers
NOTE USE WARRANTY DEALER CODING: 5A306, AS BASIC PART NO. Inspect the rivets for looseness. Replace any loose or poorly seated rivets using the following procedure. 1. Remove damaged or loose rivet: a. Drill a 3.175mm (1/8″) hole through the rivet.
b. Redrill the same hole through the shank of the rivet with a 9.525mm (3/8″) drill. c. Remove the rivet head with an air chisel. d. Drive out the rivet with a punch and hammer. CAUTION DO NOT REMOVE THE FASTENER WITH A CUTTING TORCH BECAUSE DAMAGE TO THE FRAME STRUCTURE IS LIKELY TO RESULT. 2. Line ream the hole to the replacement bolt size of 11.113mm (7/16″). 3. Clean hole of burrs after reaming so that the bolt head and nut will seat properly. 4. Install a new Bolt (56561-S2) and Nut (382400-S2), and torque to  89  ±13 N•m (66 ±10 lb-ft)
Similar threads
T
Replies
Views
895
Top stories on BroncoZone.com
T
T
Replies
Views
870
T
T
Replies
Views
822
T
T
Replies
Views
1K
T
