High-flow vs Standard-flow thermostat
kerber0s
Hey everyone.  New to the forum but super excited that I found it.  My wife just bought me a '70 sport about a month ago for birthday/Christmas present (she's a keeper).  Doing the Borgeson power steering upgrade which requires replacing the stock pulleys.  As I was putting in the new PS gearbox I discovered that there are a few holes in the radiator so I drained the coolant and pulled the radiator.  While I have the radiator out..... may as well replace the water pump and thermostat..... right?
So, stock 302 and I'm going with standard-flow water pump because I've read some posts suggesting not to use high-flow if you don't need to.  What effect would installing a high-flow vs standard-flow thermostat have?
Thanks for the help/input and I'll update my profile later today with my rig info.
-Kerb
Hi Kerb.., welcome..!
Yes.., your profile helps.., especially with cooling & carb issues.  (meaning include your location as well)
Hi-flow(s) is really meant for hi-performance (hi-rpm) engines. Your rig isn't in that catagory.
What did the coolant look like coming out..? If it was dirty.., I'd put the old radiator back in & flush the system
real good B/4 putting in a new radiator.
If the eng. was running at normal temp. at hi & low speeds....,  really no need to do the pump & 'stat. at this time.
These items are easy to get to with rad. in place in most cases. However, rad. is quick-n-easy to R&R
"Rule of thumb" is.., "if it works, don't ***** with it."  (It's your call)
Lana Kane
