HEADLIGHTS CUTTING OUT WHILE DRIVING
Whooah
My '74 Bronco Headlights and Marker lights are cutting out while I'm driving down the road at highway speed. Looking for some ideas as to what may be wrong.
-The lights flicker then cut out after I've been driving for 15+ minutes. If I stop for a few minutes, the lights come back on again for a short period then flicker & cut out again.
-Radio works fine.
-License plate light stays on, works fine.
-Wipers & heater work fine.
Pls let me know if you have any ideas . . . what is wrong? Thx.
NaturalRampage
New Jersey, Bergen County
Heya!
Sounds to me like it's a electrical issue. Check all wirings for the headlights, the manual for your truck will provide a diagram. Make sure the insulation is still intact and not contacting the body or a ground. Not much else I can say, start from the power side of the circuit and work your way to the ground to find the problem. Good luck!
Hi Whooah, welcome..!
What Rampage said....! I would add there's 3 wires to ea. headlight. 1ea. hi & lo beam.., & one ground that goes (with sheetmetal screws) to the rad. support. Those screws can work loose. :glare:
Another common culprit is the "hi beam switch" on the floor. They get dirty &/or the wires work loose. The connectors are accessable in the dr. side wheel well. :-B
Did you check tail lights when this happens..? If they also drop.., it could be the light switch itself. -Or- the connectors to it.
W
Whooah
Thanks all. Turns out the headlight switch is bad as all lights dropped during failure. Ordered a switch from Jeff's Graveyard and the H4 Composite Headlamp set from Duff's since it's a great upgrade with relays.
