new clutch kit for the 68 bronco
wischbronc68
Los Angeles, Ca.
my 68 bronco clutch went out yesterday. I stepped on the pedal and felt almost nothing and when I tried to downshift (3 speed, column shift) it wouldnt go into gear. I was able to get it back to my shop in 2nd, not stopping and timing the traffic lights (it was really late). I picked up a clutch kit from Napa (torrance auto parts) and am about ready to start the replacement. My approach will be to remove the starter, crossmember, driveshaft, exhaust crossover, clutch linkage, pull the trans and transfer case, remove the pressure plate, clutch disc, bearing and bushing, bellhousing and release lever, and finally the flywheel. Hope this sounds about right, considering I have no service manual and cant find any good step by step removal instructions. Feel free to post any advice or secrets you may have on this task and I will post some pics as I progress towards completion. Crossing my fingers and hoping for the best.
W
wischbronc68
Los Angeles, Ca.
trans and transfer case are out. Went pretty smooth, except the shifter for TC was still connected and was hanging me up for a while. 3/4" thru bolt and 9/16 bolt removed and linkage separated, and the assembly dropped right out. I kept the crossmember attached to TC and removed the 4 bolts on each side of the brackets and lowered it all down together. Kept the stock exhaust connected and it cleared it no prob. Now on to the bell housing removal. Thinking about ordering a tranny rebuild kit tomorrow and just rebuilding it since its already out.
Wow..! Good job there wisch...!!
Sounds like you have good mechanical skills. ;) /emoticons/[email protected] 2x" width="20" height="20" />
I hope you took a close look at the clutch linkage 'cause something doesn't sound right...as though something fell out or broke. Should also be able to shift gears, W/O the clutch. But., anything is possible. (shift linkage out of adjustment.)
When separating trannie/transf. do it on the trannie side of the adaptor. If you sep. adapt. from the transfer., the (output shaft) large needle bearings will likely fall into the case. :( /emoticons/[email protected] 2x" width="20" height="20" />
Same for trannie.., moving the shifter tab into 1st gear stops the possibility of the large needle bearings fr. dropping into case. (When you remove the trannie front bearing cover, the gear-set tries to move forward..allowing these bearings to drop.) No biggie when re-building as you can fish them out later.
However., if trannie was shifting fine (syncros working, etc.) B/4 this delema.., there's no real need to re-build at this time...but you'd be well served gett'n a manual unless you've done trannies B/4.
Keep us posted on progress if you would.... :D/
HTH
W
wischbronc68
Los Angeles, Ca.
Thanks Bully! The clutch linkage is definitely suspect too. It started squeeking and almost felt like it was getting hung up when the pedal was pressed or released about two weeks ago. I will pull all that stuff tonite and inspect it. I guess there's some bushings and rub washers in there that are probably all worn out. The dust boot is disintegrated also so I will find a rebuild kit for it. The shift linkage seems outta whack too, seemed to alwAys grind going into reverse unless you put it in first gear the moved it up to reverse. Second gear was kind of grindy also. Upon inspection of pressure plate and flywheel, it seems to be pretty worn out, and the throwout bearing looks and spins like those metal whheled rollerskates we all had when we were kids. I will add pics as soon as I figure out how to do it from my iPhone.
Keep the comments coming, it helps!
"...some bushings and rub washers in there are probably all worn out."
--- The good news it's cheap & easy to repl. all those teflon hat bushings, etc. involved with that mechanism. I've even made my own a time or two.
The clutch will work W/O them but the holes will elongate & get sloppy. :( /emoticons/[email protected] 2x" width="20" height="20" />
"....always grind going into reverse unless you put it in first gear then moved it up to reverse. Second gear was kind of grindy also."
--- Oh-oh...this sounds more like worn syncros...pop'n the top insp. cover will give a look at the sync's & shift forks. Maybe it is time for a re-build. :eek: /emoticons/[email protected] 2x" width="20" height="20" />
Take a look close at floor shifters when it's re-assembly time. This is one of the best up-grades you can do. :D/
W
wischbronc68
Los Angeles, Ca.
Thanks Bully. I'll pop the top and check it out.
I forgot to mention., watch out for that lil' spring that holds down the shift rail detent ball. It will be visable with the cover off. Don't lose it.
Down in the bottom of the case you'll see a magnet...(approx. 1" across) it will hold clues as to any shavings deposited into the gear oil stream. You can scoop some junk off of it with a screwdriver or like tool.
W
wischbronc68
Los Angeles, Ca.
finished the clutch/pressure plate change out. Reassembled everything and I still have a vibrating clutch pedal and pretty bad chatter in first and reverse. Motor mounts are new, trans mounts are good, everything is torqued properly. Flywheel was resurfaced. Installed new pilot bushing. wondering what to check next.
W
wischbronc68
Los Angeles, Ca.
wow, this is really frustrating!!! ok, just checked timing, adjusted carb, checked ignition, distributer, spark, dwell, basically got the 289 humming to eliminate rough engine idle as a problem. Checked u-joints, yokes, etc...All is good. Still chattering bad in first and reverse. Thinking it could be an alignment issue??? Really not sure what to do next. Clutch is engaging and disengaging properly and i have no issues in second and third. shifting smoothly between gears with no grinding. pedal feels good. feels like bad motor mounts but they are new and torqued properly. HELP!!!!!!!!!!!!!!
wisch
OUCH...!! That hurts b-(
What was the obvious problem areas on/in the clutch system that you removed.?
(Assuming you put in a new T/O bearing as well.)
What all did you do in/to the trannie itself...?
Shutter 1st & reverse ..... as in when it first starts rolling or continues as long as it's in that gear.?
Did you try starting out in 2nd...? (to see if it shutters then as well)
bigbluebronc
ca
wisch
I think I have seen this thread before and it referenced not motor mount but the hard motor mounts on the frame being torn away from the frame, just my 2 cents
BBB
Lana Kane
