1989 Bronco steering wheel
huntingidaho
I have a 1989 bronco and the sterring wheel has the cruise control in it, is there any aftermarket steering wheels with the cruise control in them? I hate the stock wheel but I really like the cruise control so if there isn't a steering wheel out there I think the cruise control will win over a nice steering wheel without cruise.
Thanks
Rob
78 blue beast
Manchester, NH
I've never seen one myself. I suppose if you good with running wires and mounting switches you can just relocate the controls. Just like some cars have them in the directional switch.
yo!
Grant makes it
Search results for:
1978 - 1991 FORD BRONCO 4WD; 2D Full Size Sport Utility; U Series
Here is da run-down; go to LINK above so you can click below products for a pic of each
Accessories > Installation Kits > Ford Cruise Control Kits
5249-C3 Optional Cruise Control Kit Std. & Tilt Columns; Will Retain Factory Cruise if so equipped; Use w/3 Spoke Signature Wheels w/o Spoke Cover Only - $195.15
5249-C4
Optional Cruise Control Kit Std. & Tilt Columns; Will Retain Factory Cruise if so Equipped; Use w/4 Spoke Signature Wheels w/o Spoke Cover Only $195.15
Accessories > Vehicle Security
2001
Optional Vehicle Security System Wheel Removal System; Must Use w/3000 or 4000 Series Installation Kit Only; Use w/Grant Wheel; Blk
Other Products
5249-1
Optional Billet Installation Kit Std. & Tilt Columns; Polished; Use w/Signature Wheels Only; Will Disable Factory Cruise if so Equipped
5249
Optional Billet Installation Kit Std. & Tilt Columns; Black Luster; Use w/Signature Wheels Only; Will Disable Factory Cruise if so Equipped
5704
Optional Banjo Installation Kit Std. & Tilt Columns; Polished; For Use w/Banjo Wheels Only; Will Disable Factory Cruise if so Equipped
3249
Steering Wheel Installation Kit Std. & Tilt Columns; Will Disable Factory Cruise if so Equipped
other strg wheel sources such as Budnik &Colorado Customs do not indicate they have a CC kit in thir web sites.
GL!
Virgil3rd
