Wire harness end piece to power window switch broke
Big Daddy Bronco
My 1995 Bronco passenger window stoped working so I pulled out the unit on the door and saw that one of the wires going to the box that the up/down switch is pushed into was broke. I just need the gold looking connector for the end of the wire that fits in the plastic box to push the up/down switch into. Any one know where I might find one.
Yo Big Daddy Bronco,
Am I correct that you need the terminal from just the wiring harness side? And not the switch connector side?
Pull the connector & take it to local Ford dealer parts dept or Automotive Electrical Repair Shop
Ford has this Ford Motorcraft® Wiring Pigtails Kits Identification Guide, Bronco/Ford truck & all Fords w/Ford WPT & Long Version Part Numbers & Illustrations w/ Component Application, 2010
I recovered it @ https://web.archive.org/web/20101121160828/http://www.fordtechservice.dealerconnection.com/Renderers/ie/wiring/svg/images/connectorcatalog.pdf
The dealer may just have the connector. Automotive Electrical Repair Shops may have the terminals & connector.
If you need the switch someday, check local parts store HELP section for:
Switch & Relay : Power Window Switch Price
DORMAN 901306 Click for more information about this part
{#49252, 49252B, E6DZ14529C} One of our most popular parts
Fits Front Right; 1 Button
Or Front Left; 1 Button $6.17
david@holycitytransportat
