Window Motor Fix
defiant
New Jersey
Here are instructions to fix the problem common to all ford window motors . These nylon barrells sooner or later all break apart. Clean out all of the broken peices and clean out the motor transmission . Next you need (6) 1/4" nuts . Place 2 nuts stacked flat on each other into each of the three holes (highlighted in the photo) . Put some fresh qualitly wheel bearing grease into the all of the transmission part of the window motor . Then reinstall the drive gear and the cover plate. Reinstall the window motor and enjoy a window that will always run trouble free until either the motor itself frys or the worm gear wears out..
Hope that you all find this little tip handy :D /emoticons/[email protected] 2x" width="20" height="20" />
Soon to come i will do a write up with photos of installing LED underbody lights for those of you that like to go wheeling in the dark. Will be trail tested with some night photos of these lights in use on the trail(maybe a few weeks cause i will be moving on the 20th of Aug).
Just used yor pointers on my passanger window ,you hit a home run ! It was a snap Thanks DEFIANT
Tattooroger
Hey there so I have a question, not only about the motor but the electrical. I have a 1990 bronco an the switch that controls the back window shows it has power going to it, when the key is turned to the on position the constant the up an down all have power but when I have the truck running there is no power to the switch at all. Now I got a new motor an it worked once but only going up an not down. I'm not sure what it could be
Thanks
Roger new bronco owner
Doug Bowles
First post on here, bringing up an older thread but i was wondering if this works for window motors on my bronco that rolled down but wont roll up? You can hear the motor working but nothing is happening. If that is the case, i will be repairing them this weekend.
yo Doug
Prob is the issue
See this article too
Motor Replacement & Repair (Motor Torque Pin (also called Bushing)) in 87, 88, 89+ "...Dorman HELP part number 74410..."
Source: by bigmercury.com http://www.bigmercury.com/bigmercury_technical.htm#pwrepair
Motor Removal & Repair in an 89
Source: by Brahma502 at http://www.supermotors.net/registry/15076/50238
Grease is only necessary on the central shaft & the outer plastic gear teeth - not in the pockets where the nuts go, though grease on the nuts may help them stay in place while the center gear is being installed.
Also clean glass track w/cotton rag dipped in dish wash soap solution; wrapped around popsicle stick; then **** track w/silicone; I prefer silicone in grease form so as not to have over-spray from aersol can on paint and glass/upholstery
bigd1948
