Vacuum Hose replacement location
Placilla
Hereford, Arizona
All of my vacuum hoses were broken or gone. I manage to connect all of them except for one.
Can someone tell me where this hose from the purge valve goes, picture 1?
While I am at it.
Does it matter which hose goes where on the canister, picture 2?
Thank you!!
Yo Placilla,
Welcome to our Bronco site!
Which year do you have?
For now, See my Vacuum leak test in post #11 includes jowens1126 HVAC Control Panel info & Mikey350's High Idle Tests @ https://www.fullsizebronco.com/threads/help-with-dtc-codes-and-idle.206824/
Excerpts:
Evaporative Emission (EVAP) Canister for the Evaporative System (aka Charcoal Canister, Vapor Canister, Carbon Canister) pic @ https://www.fullsizebronco.com/attachments/corrsoion-box-jpg.15892/ by td152
Note; use fuel-rated vacuum hose for Canister purge solenoid (CanP)
CanP vacuum hose to throttle body in a 96 pic by edamanski @ https://www.fullsizebronco.com/cdn-...zebronco.com/attachments/download-jpg.151992/
Cannister Purge Solenoid (CANP) pic @ 1990 Ford Bronco Emissions picture | SuperMotors.net
by SeattleFSB
Motech
Santa Cruz, CA:
It is difficult for me to see where that hose attaches. Is it at bottom of that solenoid? Or into the firewall.
And are you certain that's the charcoal canister? Might that be a sealed vacuum reservoir instead?
Year, model and engine size would be helpful too.
bigd1948
