Tube Doors
custom_78
San Diego, CA
Here is a picture so far
getfile.php
C
custom_78
San Diego, CA
Here is a pretty much finished picture. I have some other guys ordering them. Do any of you want them?
Just some welding and finish the latch then they're finished.
C
custom_78
San Diego, CA
No, but I'm something can be done to make them lock. But why do you need them to lock if someone can just climb over them. To latch you have to drill a 7/16 hole in your door jamb and the spring loaded pin inserts in there
BigNasty
SquirrelBait
NC
;) /emoticons/[email protected] 2x" width="20" height="20" />
:D /emoticons/[email protected] 2x" width="20" height="20" /> :D :D /emoticons/[email protected] 2x" width="20" height="20" /> :D :D /emoticons/[email protected] 2x" width="20" height="20" /> :D :D /emoticons/[email protected] 2x" width="20" height="20" /> :D :D /emoticons/[email protected] 2x" width="20" height="20" /> :D :D /emoticons/[email protected] 2x" width="20" height="20" /> :D
coop7379
wow, those are turning out great . i just have one question after doing the changes so that the tube doors will latch is if very dificult to put the stock doors back on if needed. or is it not posible. becouse im interested but i dont beleave i want to have tube doors on a frozen day becouse my bronco surves two purpeses. toy and winter driver
C
custom_78
San Diego, CA
You can interchange between the stock doors and tube doors easily within 10 minutes or less. Just unbolt the door from the lath and bolt on the other door
bigbad79
i overlooked your gauges in the pics and wondered how you put the whole set up together? looks real clean. i did something similar on my bronco but i'm not sure if i like it now that its done and i'm trying to look for inspiration. have any pics of the dash?
C
custom_78
San Diego, CA
Here it is so far. It is mounted entirely in the cage
Here is the piece I made to go in the gap from taking out the stock dash
bigbad79
it looks really clean. if i ever put a cage in mine i'll prolly do somethin similar to that. on my 79 i just ripped out the gauge cluster and put a piece of diamond plate over it and mounted my gauges to that.
Wdtdls
