Transfer case made brass bushing
johnnyreb
West Virginia
I couldn,t find any brass bushing for the transfer case shifter bushing. Plus wasn,t about to pay about $25 for the nylon ones plus shipping. I made my own .They turned out pretty good. Now I,ll grease the parts and bolt it up. I will be useing R-pins instead of the regular cotter pins. Reason--they are easier to pull out. You have one side to pull. Where cotter you have to get the ends smashed together ,Then pull and in a hard place to work in.Its hard.Hear is pictures of the brass bushing installed.
J
johnnyreb
West Virginia
Brass bushing inserted in transfer case shifter . That bolts to the side of 4 speed transmission on 78 bronco
  • brass bushing inside transfer case shifter housing-Big bolt goes through it and bolts to trans...jpg
J
johnnyreb
West Virginia
R-pins that I bought at Harbor Freight for about $6
J
johnnyreb
West Virginia
It fits nice. It took a good while to make. I had plenty of time to do it and fits really nice with no slack in it. Now I,ll try and make a pin for it. Where it goes into the rod .That works in and out the transfer case.
  • pin that holds the transfer case shifter. To the rod that works the transfer case..jpg
J
johnnyreb
West Virginia
The pin at the right. Is what holds the shifter to the rod that works the transfer case. I will be making me one. Can,nt see paying $30 for it. Rediculious.
J
johnnyreb
West Virginia
Tools I used to make the bushing . The most it took a good bit of filing and try the fit.
Gryph
