Temp gauge
Chipstone
I have a 72 Ford bronco. The temp gauge warms up to normal and then falls right away to cold again. I have changed the sensor and changed the wire leading to the sensor. All other gauges work fine can someone help me please.
C
Chipstone
I also grounded the wire and it pegged out so I know the gauge works any ideas
You may need to clean the threads (in the manifold) at the sending unit.
I don't know why but sometimes teflon tape also,  can interfere with a good ground @ screwing in the sending unit.
If the gage pegged due to grounding wire, the gage is likely good.
However, don't hold the wire to ground much more than a momentery touch.
C
Chipstone
I don't have Teflon tape on it. Thanks for getting back to me.
