Suspension Lift
Bronco Bill
I have an 83 Bronco and I want to get a 4 inch lift for it. To complete the lift, I have the 4 inch blocks, u-bolts, and new shocks. Is there anything else i will need in order to complete the lift? Thank you for your replies.
shaun94
bronco commander
hooksett N.H.
You are going to need 4inch coil's, radius arms,mounting hardware. You should check out skyjacker.com they have list of everything you need in doing a suspenscion lift.
jud
Think about extended braided steel brake line a little pricy but worth the money. Don't forget to check driveshaft lenght 4 in is borderline for needing longer ones. just a couple of points to think about...Jud ;) /emoticons/[email protected] 2x" width="20" height="20" />
Stomper4x4
Redding CA
First off, if your rear blocks are 4 inches of lift, you'll want 6 inch coils for the front. This is how most lift kits come, as it levels out the truck as well as lifting it. COntact any lift manufacturer to confirm this if you want. I agree with everyone else on blocks though, that is not to use them unless you're mostly on the street. You can spit em out on the trail, or get that axle hop goin on and break something pretty easily. Check out Sky Manufacturing, they have a shackle flip kit for around 100 bucks, that gives you 4 inches of lift with stock springs, just a thought.
Otherwise, yeah you need the brackets, pitman arm, coils, extended raduis arms or drop brackets for those....get the extended B) Check a website for typical lift components.
bigd1948
