Suspension conversion
Bad1993
I have a 1993 ford bronco xlt with the standard shock set up...I want to know what work and parts would go into a quad shock conversion any help or knowledge will be appreciated on how to complete this.
You would need to replace the upper shock/spring mount perch, and add the lower shock mount that I believe is the rear most shock. It gets bolted to the top of the traction beam.
A fair question would be why do you want to go to quad shocks?  For the looks, or for off road?  It could be easier and cheaper to go with a good quality off road shock if that is the reason.
Good Luck
Bad1993
I just wanted it for looks but I changed my mind I'm stickn with the standard shock set up.
david@holycitytransportat
