Steering column
Matts fine 79
Hello I have a 79 bronco and my steering column is gutted of all the wires and switches. I need to replace it and was wondering what other vehicles have this column? Also has anyone installed the ididit column that bronco graveyard has for sale?
Thanks Matt
yo Matt,
Some info for now;
Tilt Repair Manual Excerpts & pics in a 79
http://www.supermotors.net/registry/20292/71054
and
79 Wiring Diagrams
http://www.supermotors.net/registry/media/874639
Source: by Ranger429 (Trailer Special)
79 Ford Bronco Wiring Manual by topsig at http://www.supermotors.net/registry/24302/83503
ididit
1974-79 Bronco - Tilt Floor Shift & Column Shift
Retrofit Series
This retrofit column is designed to fit your Bronco and does NOT require modification to your original vehicle to install. This Ford Style column features all Ford wiring and a Ford top shaft and will bolt to your stock box. Simply remove your old column, saving your original floor mount. For flawless installation, a pre-welded underdash mount comes standard with every column. Using an ididit installation kit, install your new steering column in place of the old. Add your stock Bronco wheel directly to the column and the gripping surface will be in the same location as the original. Available in tilt floor shift or tilt column shift versions. The shift pattern on the column shift column allows you to use either a 3 or 4-speed automatic transmission and utilizes the original transmission mounted neutral safety switch. A gear shift indicator is an option, but not included. A shift linkage (new or original) is required for installation and will attach to the lower shift arm provided on the column.
http://www.ididitinc.com/retrofit-steering-columns-2/74-79Bronco_Retr-48
Hopefully, others will give you more info.
That idiot column is $$$
http://www.hollanderparts.com/
Select All Parts
year, etc, then FORD TRUCK
Has Vehicle Pics!
Hollander Interchange System
"What is the Hollander Interchange?
The Hollander Interchange is a numbering system that indexes which parts are interchangeable among vehicles. For example, the timing cover for a 1976 GMC Truck also fits a 1969 Corvette. For more than seventy five years, automotive professionals have trusted the Hollander Interchange to help them save time and money locating parts.
What models are covered in the books?
Hollander Interchange Manuals cover most foreign and domestic cars and light trucks from the 1920s to the present. For a complete list of year ranges, click here.
What types of parts are covered?
The manuals cover more than 150 mechanical and body parts and assemblies."
http://hollanderinterchange.net/resources.php
or
http://www.copartfinder.com/finder/searchMake.do
Has Vehicle Pics!
http://car-part.com/
http://www.picknpull.com
This is a Company name w/yard locations in various states
Some columns are sold on E bay and have been rebuilt...
also, specify your transmission type (C6 auto) or manual trans and if it is a tilt or Non-tilt columns
I believe the Bronco columns is same as F series and vans; but a yard that uses the Hollander Interchange system can verify that.
M
Matts fine 79
Thanks you guys have given me more info then I was able find on my own.
