starter spinning but tests out good
crissyray
South Caroline
Please help!!!
I have an 88 b2 automatic 2.9
Spinning starter
Used to catch when motor manually turned with tiretool now NOTHING
Replaced 3x
Replaced batt and ig switch
Tested all starters off car sounds good
Place on nose over end of bendix ground down
Can crawl under loosen up move towards a little it will catch but have to tighten back up so won't restart I think I pray it's something small but every MAN lol inmylife saying flywheel but teeth from what I can see with mirror look good
Hi Crissy..,
We can assume you're various starters are, in fact, for an "automatic" transmission..., not a stick-shift...?
Many Auto trans. have an inspection plate or a small, bolted on pan that, when removed, allow visual inspection
of the flexplate (flywheel).
"Used to catch when motor manually turned with tiretool now NOTHING"
Not sure what this means..? Do you mean cross shorting the starter terminals..?
"....loosen up move towards a little it will catch but have to tighten back up so won't restart"
Can't visualize this as well...?
