Elmo
topic seems old but hope some one still watches it
I have a 1990 5.8 auto that will not start unless I shoot it with ether ,check eneine light is on,is running very rich, if i move throttle it chokes sometimes will stall othertimes will just spit and cough,has no power ,fuel pump will cuntinue running after truck stalls, then when restarted and running at oper temp for a minute it will stumble then recover and run like there is no problem, plenty of power,plenty of throttle response, if i turn the truck off the fuel pump doesnt continue running, truck will restart fine, untill it cools down then it starts all over again. Fuel press is 35-40. Tring to check codes with a POS code reader from autozone is not comeing up with any conclusive results gonna try the jumper wire method will post results. I know my way around a vehicle can build an engine with no problem but never got too deep into the drivability diagnosis part. This thing is ******* me off though it ran through 5 gal of gas just idleing in my shop while i looked for vac leaks bad wires did notice the plugs are gapped way more than .042. this beast is completely stock no mods at all. I have replaced the air bypass valve jst because i had one on hand.
