Ron Francis Wiring
Sean@RonFrancis
[SIZE=10.5pt]Hello![/SIZE]
[SIZE=10.5pt]We at Ron Francis Wiring have been striving to provide the best products and service for over 40 years! We have excellent systems that can completely rewire your vehicle or engine![/SIZE]
[SIZE=10.5pt] [/SIZE]
[SIZE=10.5pt]Our Express panel will rewire everything from your headlights to your taillights. Our system is designed to give the user complete control over how they want the end product to look. Simply choose the location of the panel, and start running wires from your accessories to that location! We provide extra wire so you should never have to worry about running out in the middle of a job. We also provide all of the plugs necessary to plug into most of your equipment.[/SIZE]
[SIZE=10.5pt]Thinking about swapping a new motor or rewiring your current EFI system? Our Telorvek panels are excellent in running your engine and we have a large variety of harnesses for almost any engine. Or if you are tight on space, our TDZ-75 is a pre-wrapped, plug and play 5.0 harness that will drop right into your old Bronco![/SIZE]
[SIZE=10.5pt]Once you have one of our systems, you also get our excellent tech support for the life of the vehicle. We understand that wiring is not the simplest project when dealing with vehicles, but we do our best to make it as simple as possible. If you have any questions or wish to receive a FREE catalog, you can visit our website or call us at 1-800-292-1940.  http://www.ronfrancis.com/[/SIZE]
yo Sean, Thanks Again!
To help your crew & customers, here are some Wiring Diagram & TSBs;
Wiring Diagrams in 86-current and TSBs for 80 - Current by BBBMotor - Many Makes and Models
http://www.revbase.com/BBBMotor/
Wiring Diagrams (Partial, Bronco similar) for F 150 in 86, 89, 91 & 95; EEC, Start/Ignition, EFI/Fuel System, Emissions, E4OD, AOD/C6 (+ clutch interlock switch), MAP, TPS, ECT, ACT, KS) & EGR Valve Position (EVP) from Electrical & Vacuum Troubleshooting Manual (EVTM)
Source: by Ford via Ryan M (Fireguy50) at http://web.archive.org/web/20110112221736/http://fordfuelinjection.com/?p=36
Wiring Diagrams; click vehicle, year & go to Chassis Electrical & scroll (under license from Delmar Publishers, comb of Chilton/Nichols/Delmar & Haynes); some may be incorrect, as reported by Seabronc, thanks Seabronc! NEW SITE URL!!! MUST REGISTER TO VIEW; select year, make, model, engine size and go to appropriate section
Source: by Chilton via AutoZone http://www.autozone.com/autozone/myzone/profile/membershipBenefits.jsp?intcmp=sz_1&myZoneLanding=myZone
I have many more Links in my archived broncolinks.com site @
http://web.archive.org/web/20110112221736/http://www.broncolinks.com/index.php?index=143
See my Signature below to find current URL.
1979 Ford Bronco Wiring Manual by topsig
http://www.supermotors.net/registry/24302/83503
1979 wiring schematics by Ranger429
http://fullsizebronco.com/forum/showthread.php?t=223050
1996 Bronco/F-Series Workshop Manual (PARTIAL)
http://www.diesel-dave.com/vehic/manual/stj/stjleft.htm
EEC IV Connector Pin Diagram
by Fireguy50 (Ryan M) at at http://web.archive.org/web/20131229163930/http://oldfuelinjection.com/images/eec04.gif
EEC Connector Pin Outs LEGEND, Bronco & Ford Truck & Van: 4.9, 460, 5.0, 5.8; by Ryan M (Fireguy50) at
http://web.archive.org/web/20131029020805/http://oldfuelinjection.com/truckpinouts.html
bigd1948
