More of a wiring debacle!!! Need an Electrical GuRu!&#
BlueLine984
Well - thanks to the help of y'all from my first post I was able to get my 82 to crank and fire (have to jump the solenoid until I can get in and really tear into the wiring) so now I'm looking for a bit of advice on the secondary issue
Yo Nate,
I looked through 1981 Bronco/F Series Electrical & Vacuum Troubleshooting Manual (EVTM) ​​by Gary @ http://www.garysgaragemahal.com/1981-evtm.html
But no go. Doesn't  match up well enough to trust.
In case others here have info for you, be ready to tell tthem if your 82 has aan idiot (warning) light or an ammeter.
For now here is a diagram for 82 F150 alt w/warning light;
Bk/O ([SIZE=23.9997px]Black/Orange [/SIZE]and YW go to fusible link on starter relay.
Nothing else seems to match to your mangled wires.  Previous owner or shop really screwed the pooch.
Your detailed wire color identification and ignition switch pic is gone as well as my wire by wire  reply  post is gone!  Did you see it yesterday?
This isn't the first time that posts are missing here.
Any luck with local library?
