First of all why are you posting this in the bronco II section,It should be in the 78-79 bronco section...Anyway are your radius arms sitting level or are they tilted down towards the axle?If they are level stock bushings will do..If they are tilted then you need to get the ones that are a different degree for the caster.These are what you need http://broncograveyard.com/bronco/c-613 .the more tilted the more of an degree you'll need.One my 78 I have the drop down brackets on the frame so my arms are sitting level... /emoticons/[email protected] 2x" width="20" height="20" />
