Knock Sensor (KS)
Jei Jei CR
Costa Rica
Hello eveybody.
About the Ford Bronco II, 1988, V6, 2900cc engine. I wander if this engine electronic fuel injection brings with knock sensor, like this:
Knock Sensor (KS)
To prevent the replacement of good components, be aware that the following non-EEC areas may be at fault:
•Fuel (quality)
•Fuel (octane)
•Basic engine
•Spark timing
The knock sensor is used to detect engine detonation (spark knock). As a result, a voltage sent to the PCM will ****** spark timing. The KS is a piezoelectric accelerometer with the sensor designed to resonate at approximately the same frequency as the engine knock frequency. The KS uses the resonant frequency to mechanically amplify the vibrations. This method allows relatively large signals to be achieved without electrical amplification and with small package size.
http://fordfuelinjection.com/?p=34
Thanks...
Sufferedformula
