yo!
here ya go!
4WABS Self Test & Connector Diagram, Component Locations, DTCs, 93-96; USE THIS PROCESS! "...The 4WABS TEST Connector is red; located at the left-hand side (driver's side) of the engine compartment and marked ANTI-LOCK TEST; Light Flash Technique 1. Note: If 12V test light is not available, the amber ABS warning light also flashes during this test. Locate test connector in the engine compartment and install 12V test light between Pins C and E. 2. With the ignition off, jumper Pin E to B. 3. Turn key to RUN position. 4. Remove jumper between Pins E and B after 5 seconds. 5. Count light flashes of test light or amber ABS warning light..." read more
Source: by Steve83 at 4WABS Self Test & Connector Diagram, Component Locations, DTCs, 93-96; USE THIS PROCESS! "...The 4WABS TEST Connector is red; located at the left-hand side (driver's side) of the engine compartment and marked ANTI-LOCK TEST; Light Flash Technique 1. Note: If 12V test light is not available, the amber ABS warning light also flashes during this test. Locate test connector in the engine compartment and install 12V test light between Pins C and E. 2. With the ignition off, jumper Pin E to B. 3. Turn key to RUN position. 4. Remove jumper between Pins E and B after 5 seconds. 5. Count light flashes of test light or amber ABS warning light..." read more
Source: by Steve83
see the link for more info incl Codes etc.
GL!
