hood issue on 1982 bronco
jj23armbar
DFW
Good morning all,
First post but I had a bit of an odd question. So I hopped in my bronco a few weeks ago to run down to the convenience store really quick. Apparently, my hood was not properly latched and flew up during the drive.... a real bonehead move on my part. Anyway, flash forward to now... I've replaced all hood hardware, the hood itself and reinstalled but I'm not getting a perfect fit. Any theories on what I'm missing, pictured included.
Yo jj23armbar,
This is for 92-96 Broncos, but may be similar;
"Hood Alignment​
  1. Open hood (16612) and mark hood hinge (16796) and hood latch (16700) locations.
  1. Loosen inner screws attaching hood hinge to front fender (16005).
    ItemPart NumberDescription
    116796Hood Hinge
    2N803506-S55***** and Washer Assembly
    3N800538-S100U-Nut
    416612Hood
    516K700Link Assembly, Hood Hinge (RH)
    616K702Link Assembly, Hood Hinge (LH)
    716005Front Fender (LH)
    8N800628-S36Washer
    9N800297-S55Bolt
    ATighten to 17-27 Nm
    (13-20 Lb-Ft)
    BTighten to 15-20 Nm
    (11-15 Lb-Ft)
    Adjust the hood hinge up or down or rotate as required to obtain a flush fit between the hood and top of cowl panel. Tighten inner bolts attaching hood hinge to front fender.
  1. Loosen two screws attaching hood latch.
  1. Loosen screws attaching hood hinge to hood.
  1. Move the hood forward or rearward and from side to side as required for a proper hood fit. Then, tighten screws attaching hood hinge to hood.
  1. Move hood latch from side to side as required to center hood latch with the hood latch striker (16K689). Tighten hood latch attaching screws.
  1. Lubricate each hood hinge at all pivot points with Multi-Purpose Grease Spray D7AZ-19584-AA or equivalent meeting Ford specification ESR-M1C159-A and ESB-M1C106-B.
  1. Check alignment of hood and hood hinge by opening and closing hood.
  • Make sure lubricant has worked into pivot points."
●1982 Ford Bronco Sales Brochure by Ford via https://www.broncocorral.com/resources/1982_ford_bronco_brochure.pdf
by Ford via Gary
EEC III Testing, Pin-Outs, Wiring & Vacuum Diagrams in an 82 by Tommy
DIY EEC III Timing Procedure by Eric, DONOTDELETE @ EEC III - Off-Road Forums & Discussion Groups
1982 Bronco "What's New for 1982" Brochure by Ford via Gary
1982 Light Truck Facts Book by Ford via Gary
1982 Bronco Advertisement "A lion in winter!" by Ford via Gary
1982 Fastener Pictures & Illustrations by Gary
1980-1986 Bronco/F Series Carburetors, Chokes & EFI by Gary
1980-1986 Bronco/F Series Specifications by Gary @ Axle Ratios - Gary's Garagemahal (the Bullnose bible)
1982 Exterior Colors by Ford via Gary
Differences in 1980-1986 Bronco/F Series by Ford via Gary
1982 Special Performance Specifications by Ford via Gary
1982 Accessories by Ford via Gary
Haynes Red Manual for 80-95 Bronco & F Series @ Hanes guide 80-96 bko f series.pdf via BroncMom
J
jj23armbar
DFW
Yo jj23armbar,
"Hood Alignment​
  2. Loosen inner screws attaching hood hinge to front fender (16005).
    116796Hood Hinge
    3N800538-S100U-Nut
    416612Hood
    8N800628-S36Washer
    9N800297-S55Bolt
    (13-20 Lb-Ft)
    (11-15 Lb-Ft)
  3. Loosen two screws attaching hood latch.
  4. Loosen screws attaching hood hinge to hood.
  5. Move the hood forward or rearward and from side to side as required for a proper hood fit. Then, tighten screws attaching hood hinge to hood.
  6. Move hood latch from side to side as required to center hood latch with the hood latch striker (16K689). Tighten hood latch attaching screws.
  7. Lubricate each hood hinge at all pivot points with Multi-Purpose Grease Spray D7AZ-19584-AA or equivalent meeting Ford specification ESR-M1C159-A and ESB-M1C106-B.
  8. Check alignment of hood and hood hinge by opening and closing hood.
by Ford via Gary
Yes, the layout does look similar. I've had to adjust before, I took the original hood off when painting and there was a lot of slight tweaks as indicated in your reply. There wasn't anything though that impacted the "rise" or fall of the hood which is the issue here. It is all slightly adjustable, with some wiggle room both side to side and forward or back on a horizontal plane but I've got nothing really when it comes to the up or down of the hood.... sitting flush with the quarter panels. What's odd is the other side does fit flush, it's just this one corner nearest to the cab, on the driver side.
When they fly open like that it can tweak the hinges. If you cannot move the hinges down enough to line it up, you can either replace the hinges or oblong the mounting holes more to make it fit right.
J
jj23armbar
DFW
Thank you all for the help, I think that's right and I'll need to adjust mounting holes on the bracket maybe. I guess I'll try tweaking further.
Wdtdls
