Highlighted posts from Tuesday, May. 25, 2021
  • Thread starter Top stories on BroncoZone.com
  • Start date
T
Guest
Click here to view on the web
Highlighted posts
May 21, 2021 * 11 posts * 337 views
4 speed toploader Jimmy said: All lights work, but RH Side flashes slower...?...pull headlight switch out for running lites, RHS stops flashing.....But, Wait, that's just the begining. Step on brake, works, ... Read more >>
May 24, 2021 * 8 posts * 101 views
BOB MARLIN said: 1990 5.0 manual transfer case and manual hubs. Transfer will shift into 4x4 high and low with no problem. Light on the dash verifies it, but the front drive shaft is not driven. ... Read more >>
May 18, 2021 * 11 posts * 684 views
chrlsful said: drop windshield 1st (they all do even w/o the 1st 3 yr clip or dash spiners) and havea 'panel & trim" co make 1 up. I do that but pull the window slide-out frames & tilt dwn the ... Read more >>
May 19, 2021 * 5 posts * 350 views
Pinner46 said: I have an 81 xlt that I am going to do a little work to (or quite a bit) starting with a 2012 Camaro SS 6.2L L99 engine with 6L80E 6-Speed automatic. Then take the interior of ... Read more >>
May 18, 2021 * 9 posts * 470 views
miesk5 said: Yo B, Re your " ...am I risking the functionality of my rear window?" No, our 96 external tire carrier doesn't interfere with the window, however Ensure you have all the "screws" ... Read more >>
May 18, 2021 * 12 posts * 727 views
chrlsful said: ID the major components as a 2nd job after cleaning (U may need to do so w/some of these as well - to see #s, castings and stampings). What will U use this rig for, what is the ... Read more >>
May 24, 2021 * 5 posts * 352 views
miesk5 said: Yo Z, Sorry for my delay! Bassani exhaust has an excellent reputation for performance features as well as being CARB Compliant; [image] See: 96 w/PaceSetter Headers, Bassani Y ... Read more >>
May 24, 2021 * 1 post * 30 views
88 bronco fan said: Hi- I am hoping it is ok to post for sale Broncos here. It's near Portland OR. Has 89k original miles (documents) and runs well and is in good shape overalls. My uncle had it from ... Read more >>
May 18, 2021 * 7 posts * 496 views
chrlsful said: sure, easy: broncohio site hasa decoder on its frnt page: [link] Read more >>
May 24, 2021 * 1 post * 24 views
4 speed toploader Jimmy said: From an 84, gas tank [84 only], Blower motor & fan, wiper motor assy. [no rods] $ 40. each. C4 auto. trans. small case [84 only] $ 200. Various 2.8 engine parts. Solid hood, with ... Read more >>
Continue reading...
Similar threads
T
Replies
Views
782
T
T
Replies
Views
804
T
T
Replies
Views
751
T
T
Replies
Views
910
T
T
Replies
Views
1K
T
Wdtdls
