Highlighted posts from Tuesday, Jun. 07, 2022
  • Thread starter Top stories on BroncoZone.com
  • Start date
T
Guest
Click here to view on the web
Highlighted posts
June 05, 2022 * 8 posts * 133 views
El Chapo said: Looking for 86 steering wheel components must be wood grain steering wheel is ok just need the plastic pieces for cruse control etc. also looking for original radio/stereo. 86 ... Read more >>
June 02, 2022 * 3 posts * 204 views
DBStoots said: Can anyone tell me where this bushing goes on the spare tire carrier? It is approximately 2" long with inside diameter of about 1 1/4". [image] Read more >>
May 31, 2022 * 5 posts * 192 views
WABronc said: Howdy, So I found this universal unlock remote on amazon for $17 so I bought it and spent memorial day wiring it up. The antenna is kind of short and sitting inside a metal door ... Read more >>
June 03, 2022 * 31 posts * 763 views
johnnyreb said: Try Heliwig--that makes sway bars and parts out in California. They make alot of parts like that and might be of some help. Good people to deal with. Read more >>
June 06, 2022 * 1 post * 10 views
69Lover said: Wondering if any of you have made the conversion on your first gen Bronco's from vacuum to electric wipers? I have an electric setup that I want to install and am looking for some ... Read more >>
May 31, 2022 * 15 posts * 329 views
L\Bronco said: Ive got a C-6 setup on the shelf I measured 52 1\2" from the top of the bellhousing to the bottom of the "U"JOINT cup. (Cup pointed at the top of trans) That puts you close. It ... Read more >>
June 02, 2022 * 18 posts * 585 views
chrlsful said: I can do the welding, not the pic (jealous). Post #7 looks like the shop's. Got a same co's tig. Alu is a pain. Like house paintin 99.99% is the prep. Lain dwn the paint is 1% ... Read more >>
May 31, 2022 * 8 posts * 296 views
L\Bronco said: Hey Sailorlou: The instrument cluster mainly uses ground G-100 and G-200 4Wheel ABS uses G-100 G100 is on the Rad support behind the washer\coolant bottle G200 is behind the passenger ... Read more >>
June 01, 2022 * 14 posts * 611 views
Ric330 said: I've found 2 common causes of this problem. One is the white line that hooks to the vacuum motor mounted on the fender well under the right rear corner of the hood. The line deteriorates ... Read more >>
June 01, 2022 * 4 posts * 338 views
WABronc said: When you say dash pad, what is being referred to? And are you saying there is usually a speaker mounted somewhere in the dash? edit: I had no trouble mounting this floating screen ... Read more >>
Continue reading...
Similar threads
T
Replies
Views
1K
T
T
Replies
Views
1K
T
T
Replies
Views
986
T
T
Replies
Views
902
T
T
Replies
Views
841
T
bigd1948
