Gas Guage Help
Thomas 714
Greenville, Ohio
:( /emoticons/[email protected] 2x" width="20" height="20" /> The gas guage does not work on my 79 bronco. I have power to the wires at the sending unit wire end. ( It's a pulsating power. ) Should the power be pulsating? I am tring to get some info on this before I pull the gas tank. The person that had the bronco before me welded a reese hitch in back. And I will need to cut it off the frame to get to the tank. Please help
Txquadhunter
N. Texas
i'll be willing to bet your trouble doesn't fail in the wires since ya got power. the circent board on the back of these old beeats gets brittle and crack. try hittin a few wrecking yards for a good gauge cluster it'll probably fix ya right up!
davids78bronco
fabricator extraordinaire
central Oregon
I had the same problem, and did the same thing txquad suggested - swap out the guage cluster... worked like a charm
T
Thomas 714
Greenville, Ohio
:rolleyes: Fell I found out why my gas guage did not work. The float was bad on the sending unit. I was going to replace the guage cluster. But I had power to the gas guage. So I pulled the gas tank and there it was, the float.
Thanks to everyone who wanted to help me out.
Wdtdls
