Rons beast
- Joined
- Dec 13, 2007
- Messages
- 1,537
- Reaction score
- 13
The proportioning valve could be part of the problem. In a front disc rear drum set up normally the valve allows fluid to flow to the rear brakes first allowing just about 5lbs of pressure before opening and allowing fluid to flow to the front calipers. This gets the rear shoes set on the drum but not doing any real braking then the needed fluid in a lesser quantity is "proportioned to the fronts to allow proper braking bias. The lines to the front caliper are usually smaller because of the lower volume of fluid needed to pressurize the front brakes. If the proportioning valve and or lines are not correct for the system you could have the poor pedal performance. The issue could be the proportioning valve is letting fluid flow to both front and rears and the return springs in the rears are pushing the fluid back toward the master. Then the second "pump of the pedal is getting the shoes in the rear set and finally the fluid pressure is even and applied to all 4 corners.
If the PO put the front disc conversion on it may have been a problem from the beginning.
