engine specs
JesseFixesCATs
Does anybody know specs for a 1988 302 efi as in internal torque specs and running the over head like valve lash and timing specs. Im about to start a rebuild on it and i was hoping i could get some of these questions answerd before i dig into it
Thanks
Jyo Jesse
From
GENERAL ENGINE SPECIFICATIONS
http://arrc.ebscohost.com/statics/p5/images/sm/isbn_graphics_complete/8828/chiltonimages/8828/88283c25l.gif
http://arrc.ebscohost.com/statics/p5/images/sm/isbn_graphics_complete/8828/chiltonimages/8828/88283c26l.gif
1987-91 VALVE SPECIFICATIONS'
http://arrc.ebscohost.com/statics/p5/images/sm/isbn_graphics_complete/8828/chiltonimages/8828/88283c27l.gif
1987-91 CAMSHAFT SPECIFICATIONS
http://arrc.ebscohost.com/statics/p5/images/sm/isbn_graphics_complete/8828/chiltonimages/8828/88283c30l.gif
1987-91 CRANKSHAFT AND CONNECTING ROD SPECIFICATIONS
http://arrc.ebscohost.com/statics/p5/images/sm/isbn_graphics_complete/8828/chiltonimages/8828/88283c33l.gif
1987-91 PISTON AND RING SPECIFICATIONS
http://arrc.ebscohost.com/statics/p5/images/sm/isbn_graphics_complete/8828/chiltonimages/8828/88283c36l.gif
1987-95 TORQUE SPECIFICATIONS
http://arrc.ebscohost.com/statics/p5/images/sm/isbn_graphics_complete/8828/chiltonimages/8828/88283c39l.gif
To properly rebuild an engine, you must first remove it from the vehicle, then disassemble and diagnose it. Ideally you should place your engine on an engine stand. This affords you the best access to the engine components. Remove the flywheel or flexplate before installing the engine to the stand.
Now that you have the engine on a stand, and assuming that you have drained the oil and coolant from the engine, it's time to strip it of all but the necessary components. Before you start disassembling the engine, you may want to take a moment to draw some pictures, or fabricate some labels or containers to mark the locations of various components and the bolts and/or studs which fasten them. Modern day engines use a lot of little brackets and clips which hold wiring harnesses and such, and these holders are often mounted on studs and/or bolts that can be easily mixed up. The manufacturer spent a lot of time and money designing your vehicle, and they wouldn't have wasted any of it by haphazardly placing brackets, clips or fasteners on the vehicle. If it's present when you disassemble it, put it back when you assemble, you will regret not remembering that little bracket which holds a wire harness out of the path of a rotating part.
You should begin by unbolting any accessories still attached to the engine, such as the water pump, power steering pump, alternator, etc. Then, unfasten any manifolds (intake or exhaust) which were not removed during the engine removal procedure. Finally, remove any covers remaining on the engine such as the rocker arm, front or timing cover and oil pan. Some front covers may require the vibration damper and/or crank pulley to be removed beforehand. The idea is to reduce the engine to the bare necessities of cylinder head(s), valve train, engine block, crankshaft, pistons and connecting rods, plus any other 'in block' components such as oil pumps, balance shafts and auxiliary shafts.
Finally, remove the cylinder head(s) from the engine block and carefully place on a bench. Disassembly instructions for each component follow later in this section.
The tools required for an engine overhaul or parts replacement will depend on the depth of your involvement. With a few exceptions, they will be the tools found in a mechanic's tool kit (see Section 1 of this manual). More in-depth work will require some or all of the following:
  • A dial indicator (reading in thousandths) mounted on a universal base
  • Micrometers and telescope gauges
  • Jaw and *****-type pullers
  • Scraper
  • Valve spring compressor
  • Ring groove cleaner
  • Piston ring expander and compressor
  • Ridge reamer
  • Cylinder hone or glaze breaker
  • Plastigage®
  • Engine stand
The use of most of these tools is illustrated in this section. Many can be rented for a one-time use from a local parts jobber or tool supply house specializing in automotive work.
Occasionally, the use of special tools is called for. See the information on Special Tools and the Safety Notice in the front of this book before substituting another tool.
OVERHAUL TIPS
Aluminum has become extremely popular for use in engines, due to its low weight. Observe the following precautions when handling aluminum parts:
  • Never hot tank aluminum parts (the caustic hot tank solution will eat the aluminum.)
  • Remove all aluminum parts (identification tag, etc.) from engine parts prior to the tanking.
  • Always coat threads lightly with engine oil or anti-seize compounds before installation, to prevent seizure.
  • Never overtighten bolts or spark plugs especially in aluminum threads.
When assembling the engine, any parts that will be exposed to frictional contact must be prelubed to provide lubrication at initial start-up. Any product specifically formulated for this purpose can be used, but engine oil is not recommended as a prelube in most cases.
When semi-permanent (locked, but removable) installation of bolts or nuts is desired, threads should be cleaned and coated with Loctite® or another similar, commercial non-hardening sealant.
Before the engine and its components are inspected, they must be thoroughly cleaned. You will need to remove any engine varnish, oil sludge and/or carbon deposits from all of the components to insure an accurate inspection. A crack in the engine block or cylinder head can easily become overlooked if hidden by a layer of sludge or carbon.
Fig. 1: Use a gasket scraper to remove the old gasket material from the mating surfaces
Most of the cleaning process can be carried out with common hand tools and readily available solvents or solutions. Carbon deposits can be chipped away using a hammer and a hard wooden chisel. Old gasket material and varnish or sludge can usually be removed using a scraper and/or cleaning solvent. Extremely stubborn deposits may require the use of a power drill with a wire brush. If using a wire brush, use extreme care around any critical machined surfaces (such as the gasket surfaces, bearing saddles, cylinder bores, etc.). USE OF A WIRE BRUSH IS NOT RECOMMENDED ON ANY ALUMINUM COMPONENTS. Always follow any safety recommendations given by the manufacturer of the tool and/or solvent.
 CAUTION
Always wear eye protection during any cleaning process involving scraping, chipping or spraying of solvents.
An alternative to the mess and hassle of cleaning the parts yourself is to drop them off at a local garage or machine shop. They should have the necessary equipment to properly clean all of the parts for a nominal fee.
Fig. 2: Before cleaning and inspection, use a ring expander tool to remove the piston rings
Remove any oil galley plugs, freeze plugs and/or pressed-in bearings and carefully wash and degrease all of the engine components including the fasteners and bolts. Small parts such as the valves, springs, etc., should be placed in a metal basket and allowed to soak. Use pipe cleaner type brushes, and clean all passageways in the components.
Use a ring expander and remove the rings from the pistons. Clean the piston ring grooves with a special tool or a piece of broken ring. Scrape the carbon off of the top of the piston. You should never use a wire brush on the pistons. After preparing all of the piston assemblies in this manner, wash and degrease them again.
Fig. 3: Clean the piston ring grooves using a ring groove cleaner tool, or . . .
Fig. 4: . . . use a piece of an old ring to clean the grooves. Be careful, the ring can be quite sharp
 WARNING
Use extreme care when cleaning around the cylinder head valve seats. A mistake or slip may cost you a new seat.
When cleaning the cylinder head, remove carbon from the combustion chamber with the valves installed. This will avoid damaging the valve seats.
REPAIRING DAMAGED THREADS
Fig. 1: Damaged bolt hole threads can be replaced with thread repair inserts
Fig. 2: Standard thread repair insert (left), and spark plug thread insert
Fig. 3: Drill out the damaged threads with the specified size bit. Be sure to drill completely through the hole or to the bottom of a blind hole
Fig. 4: Using the kit, tap the hole in order to receive the thread insert. Keep the tap well oiled and back it out frequently to avoid clogging the threads
Fig. 5: ***** the insert onto the installer tool until the tang engages the slot. Thread the insert into the hole until it is  1 ⁄ 4 –  1 ⁄ 2 turn below the top surface, then remove the tool and break off the tang using a punch
Several methods of repairing damaged threads are available. Heli-Coil® (shown here), Keenserts® and Microdot® are among the most widely used. All involve basically the same principle — drilling out stripped threads, tapping the hole and installing a prewound insert — making welding, plugging and oversize fasteners unnecessary.
Two types of thread repair inserts are usually supplied: a standard type for most inch coarse, inch fine, metric course and metric fine thread sizes and a spark lug type to fit most spark plug port sizes. Consult the individual tool manufacturer's catalog to determine exact applications. Typical thread repair kits will contain a selection of prewound threaded inserts, a tap (corresponding to the outside diameter threads of the insert) and an installation tool. Spark plug inserts usually differ because they require a tap equipped with pilot threads and a combined reamer/tap section. Most manufacturers also supply blister-packed thread repair inserts separately in addition to a master kit containing a variety of taps and inserts plus installation tools.
Before attempting to repair a threaded hole, remove any snapped, broken or damaged bolts or studs. Penetrating oil can be used to free frozen threads. The offending item can usually be removed with locking pliers or using a *****/stud extractor. After the hole is clear, the thread can be repaired as shown in the kit manufacturer's instructions.
I have to del history & temps because I can nor C&P well now;
here is one more item I couldn't C&P
Vehicle Emission Control Information(VECI), PUK (49 States) Decal, PGP (Canada) Decal, Vacuum Diagrams & Calibration Parts List for 88 & UP now On-Line at Ford:
go to http://www.motorcraftservice.com
Click "What's New" in left panel
Scroll to: "VECI labels are now accessible through Quick Guides without a subscription."
Enter applicable info (need to know your Calibration number off of your PCM or driver B pillar sticker)
In this example D1T4 is the required number.​
& Emission Parts with Ford MC PN's:
EXAMPLE, NOT for your Year...
NAME/DESCRIPTION ENGINEERING NO. SERVICE NO.
SENSOR ASSY, Catalyst Exhaust Gas Oxygen Monitor- DOWNSTREAM F65F 9G444-CA F65Z 9G444-C
RESERVIOR ASSY, EGR Vacuum F4UE 9E453-CA F4UZ 9E453-C
CONTROL ASSY, EGR Vacuum Regulator FOTE 9J459-A1A FOTZ 9J459-A
SENSOR ASSY, EGR Pressure Valve F48E 9J460-BA, BB F4ZZ 9J460-B
VALVE ASSY, Thermactor Air Control Solenoid Vacuum E7TE 9H465-AA E7TZ 9H465-A
VALVE ASSY, Thermactor Air Control Solenoid Vacuum E7TE 9H465-BA E7TZ 9H465-B
SENSOR ASSY, Exhaust Gas Oxygen - UPSTREAM F68F 9F472-AA F68Z 9F472-A
etc
J
JesseFixesCATs
Sorry i havent been replying my phone never gave me a notification. Thanks for all of the awesome info. I will be using it!!
J
JesseFixesCATs
When i try to open one of your links in the your first post it wants me to log into ebsco. Why is this?
