brake rotors
murph
North Carolina
I've got a 91 full size. I'm trying to get the wheel hub off to replace the rotor. I've done everything the manual says to do but the outer gear will not come out. Noone I know can tell me why. Does anyone have any suggestions?
murph
murph
North Carolina
Ok I got the gears out. Do I need to pull the spindle and bearings out to get the rotor off?
White90Bronco
Do you have the special 4WD Socket, or have you got past that already? If not you have to purchase a special Socket from Autozone or a similar store for your year Bronco.
murph
murph
North Carolina
I finally finished. Thanks for your help. This is the first time I've done brakes on a 4x4. I'm sure I'll be back for more advice.
