Body panel, need help finding out what it's really called. Pease h
jasindude1
So I got dinged in a parking lot, they hit the drivers side front. Not much damage, but in need of help identifying a part, what is the part called right under the headlight assembly's and grille called? , it's the metal piece that that runs directly below the grille and directly above the bumper and meets up with the fender on both sides. I can't for the life of me think of what this would be called, the damage isn't that bad but wanted to price a new bumper and whatever that piece is called bc it has a pretty good amount of separation. Thanks for ur help.
Yo jasin,
Image from Parts Catalog 87-91 & 92-96 Bronco (Partial) Source: by Ford via me at http://www.supermotors.net/registry/3549/77108
To show all images on one page, under miesk5's name in upper left, click Select Alternate View; click; Large Images + Captions & Forums Links
INDEX, paint codes, front bumper, PAGE 833
ABS module, sensor, decel switch, etc., air bag module, monitor, sensor, etc., underhood dimensions in mm, cruise control, wheels, frame, PAGE 836
front suspension, PAGE 837
grille, front lamps, headlight, hood, engine cooling: radiator, fan, water pump, shroud, page 834
paint stripes incl. NITE, HVAC, fender, PAGE 835
steering column & linkage, gear, pump, wheel & horn switch, Page 838
steering cont'd, ignition switch, Engine, Page 839
engine & trans CONT'D, alternator, battery cables, air intake, hood, HVAC CONT'D, Page 840
center console, dash, instrument panel, cowl, PAGE 841
front floor pan, seat belt, interior & exterior door trim, cab step, page 842
door CONT'D, cab roof, camper top, overhead console, page 843
tailgate, quarter glass, interior & exterior trim, PAGE 844
fuel tank, rear suspension, 8.8, floor pan, glass, tire carrier, rear lamps, high mtd. stop lamp, page 845
license lamp, bumpers, grille, CONT'D, PAGE, 846
engine & transmission CONT'D, exhaust & catalytic converter, air intake, hood, HVAC, CONT'D, Page 848
fender, paint stripes, ext trim, wheels, CONT'D, page 849
wheels, front suspension, steering linkage/column, CONT'D, PAGE 850
frame, strg column, windshield, cowl & dash, CONT'D PAGE 851
instr panel, ctr console, front floor pan, interior door trim, seats belts, CONT'D, PAGE 852
glass, vent, cab roof, camper top, side quarter glass, quarter panel, CONT'D, PAGE 853
quarter panel, tailgate, rear suspension, 8.8, fuel tank, tire carrier, CONT'D Page 854
fuel tank, rear floor pan, lamps, rear bumper, CONT'D, PAGE 855
http://www.diesel-dave.com/vehic/manual/stj/images/n11189c.gif
Item Part Number Description
1 N806851-S100 Nut
2 8326 Radiator Air Deflector
3 N805230-S55 *****
4 N623332-S100 Nut
5 N807260-S55 *****
6 17E940 (LH) Front Bumper Stone Deflector Filler
7 17E902 (RH) Front Bumper Stone Deflector Filler
8 N801603-S55 *****
9 17626 Front Valance Panel
10 8200 Radiator Grille
11 8A284 Radiator Grille Opening Panel Reinforcement
A —Tighten to 3-71 Lb-IINCHES
B —Tighten to 9-18 Lb-INCHES
C —Tighten to 35-80 Lb-INCHES
Check;
http://shop.broncograveyard.com/Bronco-92-96/products/1163/
