Best gear ratio for rear end.
Recently rebuilt motor. Makes A bit more power now. I have stock suspension for now. But 33inch tires. I want to say I have 3.55 gears now but would want more low end power. Would getting a higher gears better help this. Thanks for any help.
Yo broncoboyerusa,
Start with "Changing tire size affects the final drive ratio. Switching from a 30" tire to a 35" tire changes the final drive ratio by about 17%. This may drop the engine out of its' "power band" and result in poor performance and fuel economy. To restore performance you must change the gear ratio to compensate for the change in tire size. If you originally had 3.07 gears you need a ratio that is approximately 17% lower, such as 3.55. If you want to increase off road performance you might want a 4.10 or lower ratio." by  RANDYS Worldwide Automotive
Gear Ratio Guide for Larger Tires
Source: by Jeff's Bronco Graveyard via Fred W (Rosie, SeSeabronc)
Gear Ratio Guide for Larger Tires by Rough Countr
You desire to be in the Green zone for Most Power and Towing, Reduced Fuel Economy.
"...Ford built our Broncos & other 4x4 trucks & vans with a numerically lower front gear ratio in the front Dana 44 than the rear so that off-road steering is enhanced. A Bronco built with 3.55 rear ratio would have a 3.54 ration in the front Dana 44; or; 3.08 in the 8.8 & 3.07 in the Dana 44; or 4.11 in the 8.8 & 4.10 in the Dana 44, etc..."; Following was in my MS WORD Notes and the source, Randy's Ring & Pinion has removed it from their current web site; The gear ratio in the front of a four wheel drive has to be different from the front so the front wheels will pull more. There have been many different ratio combinations used in four-wheel drive vehicles, but not so that the front will pull more. Gear manufactures use different ratios for many different reasons. Some of those reasons are: strength, gear life, noise (or lack of it), geometric constraints, or simply because of the tooling they have available. I have seen Ford use a 3.50 ratio in the rear with a 3.54 in the front, or a 4.11 in the rear with a 4.09 in the front. As long as the front and rear ratios are within 1%, the vehicle works just fine on the road, and can even be as different as 2% for off-road use with no side effects. point difference in ratio is equal to 1%. To find the percentage difference in ratios it is necessary to divide, not subtract. In order to find the difference, divide one ratio by the other and look at the numbers to the right of the decimal point to see how far they vary from 1.00. For example: 3.54 ÷ 3.50 = 1.01, or 1%, not 4% different. And likewise 4.11 ÷ 4.09 = 1.005, or only a 1/2% difference. These differences are about the same as a 1/3" variation in front to rear tire height, which probably happens more often than we realize. A difference in the ratio will damage the transfer case. Any extreme difference in front and rear ratios or front and rear tire height will put undue force on the drive train. However, any difference will put strain on all parts of the drivetrain. The forces generated from the difference have to travel through the axle assemblies and the driveshafts to get to the transfer case. These excessive forces can just as easily break a front u-joint or rear spider gear as well as parts in the transfer case."
4:56 Installation Info & pics & drain plug in an 89 Dana 44
Source: by Tim C (TnTbronco2, Trail Truck, Street Truck, Crazed, Broke, OoG)  4:56 Installation Info & pics in a 96 8.8
Source: by Scott M (Big Bronco, Scottmoore23)
5.13 Installation pics in a 96 Dana 44 & 8.8
Source: by Al S (White Cloud, Owl)
4:56 Instalkation in a 90 Eaton 8.8
by Dave B.
Choosing the right Ratio
david@holycitytransportat
