Auto hub locknut socket?
Stan
I have a '95 with the Dana 44 TTB and automatic locking hubs. I recently found out the hard way that my hubs are shot by burying my truck to the frame at the beach in the soft sand. How embarrassing! Anyways, I have just ordered the warn premium manual hubs and conversion kit but I can't find the correct socket to remove the old ones anywhere. Have checked auto parts stores, the dealership, tool specialty shops, brake shops...just about everywhere except MAC or Snap-on. The outer cap has three Torx screws in it and the locknut itself has six slots on the outer perimeter, not four. Any ideas? Website, catalog? Thanks!
Stan
"Semper Fi"
'95 Bronco Eddie Bauer 4X4 W/5.8L
Msd 6AL ignition w/MSD Blaster 2 coil
Perma-cool twin electric fans
Edelbrock performer intake manifold
BBK twin throttle body
K&N fuel injection performance kit
Hypertech chip
Hedman elite hedders (completely wrapped down to the cats)
custom true dual exhaust
Magnaflow performance cats
Flowmaster super 40 series mufflers
Ford racing 9mm wires
Bosch platinum plugs
Optima red-top battery
Factory 8.8 traction-lock rear axle with 3.55's
32x11.50x15 BFG all-terrains
yo Stan!
95/96 factory 3 ***** auto hubs are revised from earlier years and they have a diff shaped socket; rounded edge type, like this;
Front Bearing Locknut Socket (OTC 6795 for 95-96); w/pics by OTC via thetoolwarehouse.net
http://www.thetoolwarehouse.net/shop/OTC-6795.html
you can use a chisel to remove it since it's torqued to only 16 Lb-In & you won't need it anymore
How many screws are there in the hub's cover?
if 3 torx ***** cover; you need a conversion kit along w/the Man. Hubs
and;
it's a good DIY project; about 1 to 2 hours
And, too many articles show diff. specs...must get to everyone to clear this up soon. I know Froggman will do a write-up soon w/everything needed + proper specs. & Lock nut socket tools/info; as Topher has done, see below...
5 ***** Cover Swap by Topher: http://bronco.tophersworld.com/writeup_hubs.htm
btw, he was replacing bearings too so if you're not doing that, skip those & caliper and brake pads sections.
And no need to remove wheel/tires or jack it up.
and Chris wrote to me about the BEARING LOCK NUTS TORQUE; something other articles do not fully address well & offered this:
"Word for word from Haynes Manual
Ford Pickups and Bronco 1980 - 1996
Using a lockout spanner (ford # T59T-1197-B or equivalent ) and a torque wrench, tighten the inner bearing adjusting nut to 50 foot pounds while rotating the wheel back and forth and seating the bearing.
Back off the adjusting nut approximately 45 degrees.
Assembler the lock washer by turning the inner lockout to align the pin with the nearest hole in the lock washer. To lock it, install the outer lock nut and tighten it to 150 foot pounds.
Grab the top of the tire with one hand and the bottom of the tire with the other. Move the tire in and out on the spindle. End play should be less than .006
S
Stan
Hey Miesk5,
I appreciate the info on the conversion from auto to manual, however the tool you specified will not fit my axle. The tool is described as a "special rounded" hexagonal socket, and my automatic hubs are completely round and smooth except for the six grooves spaced evenly around its perimeter. I'm just going to tap them off with a mallet and chisel or some sort of brass punch since they're going straight in the garbage when I'm done anyways. Plus, it's makes more sense than buying a tool which you will only use once.
Thanks,
Stan
S
Stan
Excellent info this time with details and pics to boot! Should be a snap. I can't wait to get back to the beach for round two!
Thanks again,
Stan
Sufferedformula
