96 Eddie Bauer remote module location
vertbird
Folks, I've recently purchased a 96 Bronco Eddie Bauer that is in good shape but didn't have the remote key fob.  The seller didn't know if it ever came with one, the Ford dealer can't tell me either.
I've seen a couple of posts here but the remote module / grey pin connector location seems different for almost every year.  I can't see the grey connector taped to any wire at the base of the steering column.  I've looked behind the glove box and there is a black box fastened there, but I still don't see the grey connector with 2 pins in it anywhere close.  The only place I see an open 2 pin connector is fastened under the front of the dash directly under the ashtray.  Seeing no one has suggest that location, I'm guessing it must be for something else.  Anyone got a 96 Bronco that knows where their remote module or grey connector is located?
Thanks!
Yo vertbird,
Module Location in a 96; from 1996 Bronco-F-Series Workshop Manual; ..."The remote entry receiver module is located in the LH side of the lower instrument panel (04320) to the right of the steering column, just above the driver's right foot area. Disconnect the three electrical connectors and the antenna connectors and the antenna connector from the module. Remove two bolts attaching the module to its support bracket and remove the module..."
Source: by Ford
Module & Programming Connector Location Diagram Ford Part Numbers, Depictions, etc. from Ford Workshop Manual in 96 Bronco, F-150, F-250, F-350, F-Super Duty Chassis Cab & Motorhome Chassis; use your Browser's SEARCH (or FIND) function to locate what you seek in each Diagram, such as remote, etc.
http://www.thedieselstop.com/faq/9497faq/maint/stj/stji1015.htm
Next time, please fill out your Signature with year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. for better responses.
In pop up,
Click, My Profile
Enter info
Click, Save Changes
To post a pic from your PC, TABLET, etc., just below the reply box in lower right corner, click More Reply Options
Screen will change
See Attach files
pick out the pic
Click Attach This File
or click, Try our advanced uploader (requires Flash 9)
Our sponsor, Jeff at the Bronco Graveyard has offered a 2% discount to members of The BroncoZone for on line orders. To get your discount, enter the discount code BZMEMBER. Also you must include your BroncoZone User Name with the order.
http://broncograveyard.com
96 Bronco-F-Series Workshop Manual (PARTIAL) by FORD via
96 Bronco Owners Guide by Hiller Ford @
http://www.hillerford.com/resource_library/owner_manuals_pdf/1996_owner_manuals_ford/96bronco.pdf
96 Bronco Dealer Brochure by Ford via me @ http://www.supermotors.net/registry/media/877777
Wiring Diagrams (not all systems shown) in 86-current and Technical Service Bulletins (TSBs) for 80 to Current
http://www.revbase.com/BBBMOTOR/
Recalls, check with VIN at dealer or on-line @ Ford; esp. 94-96 Bronco, 94-02 F-150, etc. was performed, have VIN ready. "Summary: ON CERTAIN PICKUP TRUCKS, PASSENGER VEHICLES, SPORT UTILITY VEHICLES, AND MOTOR HOMES CHASSIS, THE SPEED CONTROL DEACTIVATION SWITCH MAY, UNDER CERTAIN CONDITIONS, LEAK INTERNALLY AND THEN OVERHEAT, SMOKE, OR BURN. THIS COULD RESULT IN AN UNDERHOOD FIRE."
https://owner.ford.com/tools/account/maintenance/recalls.html?pagename=Owner/Page/RecallsPage&gnav=footer-owners
Also, register to see any Ford dealer maintenance/repairs done @ any dealership nation-wide @ http://owner.ford.com
