96 Bronco - Rear End Problems
S
Stephen Kelly
Guest
I was wondering if anyone had any experience with a "thump" in the rear end when the truck is first starting out and coming to a stop. I just had a rebuilt transmission put in and it is shifting great; however, I've always had this "thump" in the rear end. It seems to be more evident when the truck has been driven awhile.
Thanks for any input.
davids78bronco
fabricator extraordinaire
central Oregon
If you come back here to read this -
Check a few things: make sure the Ubolts are still tight, keeping the spring pack tight to the spring perches on the axle. Make sure the spring perches themselves are rounded over at the ends. Have your rear diff checked out... the gears might be ruined
T
TheBroncoMan
Guest
Could be the driveshaft, slip joint. Check it also.
azrockrat
kingman az
also check the bolt holding your pinion in place if that gets loose that will cause the same sound
Sufferedformula
