94 bronco 5.8 will start but just dies
Bigbronco94
It started on the interstate driving fine then just dies starts up idles fine but you step on it just falls on its face I've replaced the fuel filter, cap and rotor, IAC, check fuel pressure it's fine. now it won't start at all I've checked the fuel pump relay it's fine and decided to check the fuel pump and still no luck also have checked to see if the timing was off but that's fine too please someone help me!!!
Yo Bigbronco,
http://broncozone.com/topic/14269-code-reader/?pid=74587&mode=threaded
Some basics;
Run it to heat the engine up and shift thru all gears including Reverse.
Do KOEO test First
KOEO
KOER
Until we see any codes, if there are any,
This is by Ford in 1994 PCED OBDI-A
SECTION 2A: Diagnostic Routines
Diagnostic Routines Symptom Flow Charts — Chart 4
Symptom
Starting Concerns
—No Start/Normal Crank
Note: Extended cranking because of a "No Start" can load the exhaust system with raw fuel, damaging the catalytic converter after the engine starts. After the "No Start" condition has been repaired, disconnect the secondary air supply, run the engine until surplus fuel is used up, and reconnect the secondary air supply.
http://www.thedieselstop.com/faq/9497faq/maint/vra/vra02009.htm#vra02chart4
Check Fuel quality: air intake from intake atop radiator support to throttle body.
Inertia switch tripped, inside passenger side kick panel
How to Troubleshoot a No Start
(Ford 4.9L, 5.0L, 5.8L)
Cranks, but no start;
http://troubleshootmyvehicle.com/ford/4.9L-5.0L-5.8L/how-to-troubleshoot-a-no-start-1
