84 BII - brake lights AND rear turn signals not working
b2bomber
Both left and right rear turn signals and brake lights do not work. Front signals OK. Running lights will come on when I turn the lights on, but that's it.
Replaced all four rear bulbs - OK
Tested all fuses, both sides of fuses - OK
Replaced fuse for brakes.
Tested sockets with test light - power only to one side of upper socket, none on lower.
Tested wire behind socket with test light - same as above.
Not sure where to go from here. Seems like something up front rather than a faulty wire in between. Friend suggested replace brake switch by pedal?
HELP! driving without brake lights AND turn signals is scary.
b2bomber
Figured it out. If anybody else has this problem, check to see if your system is hooked up to a switch for towing...mine is. I was on the wrong setting.
david@holycitytransportat
