351 windsor
MudCountry86
Hey everyone, finally got the bronco home. The knock seemed pretty deep in the motor however when I removed the oil pan I found the rod bearings were loose. I'm still debating on trying to rebuild this motor or get a whole different one. I'm not sure of any other possible damages in the motor yet. Need advice on if I should rebuild this one, get a different one used, or even a brand new one. Anyone's I site would be helpful and if you know of any sites etc that sells what I would need cheaper id like to know. Thanks guys!
yo Mud,
Consider Ford Remanufactured Transmissions & Engines - Motorcraft® Brand, Broncos & all Ford
Halli wrote on 30 DEC 2010 that for a Ford Reman 5.8l long block it is 2308.00 exchange. 2210.00 for a 5.0; These are Ford dealer prices in the Mid-South Reman 5.0 = $1914.56
JR Nice wrote on 5 MAY 2012, Ford crate 5.0 H.O was about $1900. My local rebuild on my 5.8 was about $2300.
radiolotek wrote on 19 May 2012, $2300. For a complete assembly (1995 5.8)
http://www.fordinstallersupport.com/files/catalogs/ptm200.pdf
 (19MB pdf)
get some estimates from the; Distributors (listed in each Catalog above) & Ford dealers;
Here is latest RETAIL price from Ford Parts on-line; see if local dealer will discount.
E4TZ-6V012-ARM
(176)
http://www.fordparts.com/Commerce/CatalogResults.aspx?y=1986&m=Ford&mo=Bronco#Search
Engine Long Block
5.8L 351 CID 8 Cylinders; w/o Dipstick in Block
                               $2,557.33
Ford has a good guarantee and the Qual is up there. And the Ford reman trannys/engines do not need to be installed by a Ford Dealer
Look at this Excerpt; (Ford guarantee shown below reportedly has been extended according to some friends)
"...Ford and Motorcraft Remanufactured Transmissions and Gas Engines
Ford Motor Company, The American Road, Dearborn, MI 48121 (“Ford”) provides the following Limited Warranty on Ford and Motorcraft Remanufactured
Transmissions and Gas Engines to Ford, Lincoln and Mercury Dealers (each being a “Dealer”) or general Installers (each being an “Installer”). This Limited Warranty provides that Ford will credit the Dealer or Installer for repairing or replacing, at Ford’s option, any Ford or Motorcraft Remanufactured Transmission or Gas Engine sold by Ford that is found to be defective in factory-supplied material or workmanship subject to the following terms, conditions and limitations:
Retail Customers: To obtain warranty service, please return your vehicle to any Ford, Lincoln or Mercury Dealership or return to the Installer who
originally installed the Ford or Motorcraft Engine or Transmission Assembly in your vehicle. Please have your original dated receipt for installation date verification.
Complete Gas Engine Long Block Assemblies (6006/6V012) and Transmission Assemblies (7000/7V000/7003)
• 36 months or 36,000 miles from warranty start date, whichever occurs first. Ford will cover 100% of all parts and labor at approved warranty reimbursement rates
• If installed by a Dealer, reasonable towing charges (up to 35 miles or to the nearest Dealer) are covered only if the vehicle is not covered under
another towing insurance coverage Short Blocks (6009/6V009), Cylinder Heads (6049/6V049) and Crankshaft Kits (6303/6V303) for Gas Engines
• 12 months or 12,000 miles from warranty start date, whichever occurs first. Ford will cover 100% of all parts and labor at approved warranty reimbursement rates
Warranty Start Date
• Ford and Motorcraft Remanufactured Transmissions and Gas Engines installed by the Dealer or Installer—warranty begins on the date of installation
• Ford and Motorcraft Remanufactured Transmissions and Gas Engines sold by Dealer or Installer over-the-counter or to a retail purchaser—
on the date of sale
Limitations to the Warranty
The following limitation applies to the products covered by this Limited Warranty
• Towing charges are not reimbursable for Ford and Motorcraft Remanufactured Transmissions and Gas Engines sold
over-the-counter by a Dealer or Installer..."
read more incl the;
"No-Risk" Core Return policy means accurate quotes for engine and transmissions are no problem. 100 percent core credit will be given (regardless of damage or quality of returned core); just follow these guidelines and the return runs
smoothly.
• Returned core is the same part as the assembly purchased
• Core is 100% complete with all parts attached and all fluids drained and is returned in original package..."
If you decide to rebuild it yourself, I'd recommend that you have a shop do the crank and balance. While you are at it, you could have it bored out a little, ported and polished, head surface ground nice and flat, etc.
Good luck with your project,
M
MudCountry86
Does anyone know if I can purchase a low profile oil pan that will come off without having to remove the motor?
