3 Speed Column Shift 68 Bronco
wpbronco
I never had any experience with a column shifter before and am looking at purchasing a 68 bronco with this setup. First question is the stupid one. What is the shift pattern? Is there any internet site showing the pattern?
2nd question is how hard is it to convert to a floor shift. The truck has the 6 cylinder engine.
admin1
Supreme Commander
Administrator
I used to have a bronco with the manual shifter on the column and it seems like the pattern was like this...
R 2
1 3
I know for sure that the floor shifter conversion use this pattern. They are easy to convert to a floor shifter, Hurst makes a good kit that can be installed in an afternoon.
Hope that helps
Bronco1978
Changing over to a floor shift isnt a bad idea,as parts for the 3 on the tree are getting harder to find (shift fingers,shift rods,shifting lever)although you can buy the shift tube,bushings and rod clips.If it works,you might want to leave it as is....if you speed shift or think column shifting is dorky,go to the floor unit,but dont cut up any more floor than needed (added noise,exhaust/engine smells...heat).
W
wpbronco
Thanks for the feedback. Went and picked up my first bronco on Sunday. The three on the column shifts fine though I am having to get used to the clutch. So I guess for now I will stick with it where it is. Good points on the hole in the floor as I had not thought of the negatives. Many other things to do but the body is in real good shape with no "holy" rust. Hardly any modifications and still has original paint job (Sea Foam Green?).
I am sure I will have questions for the future since this is my first bronco.
Broncoholic
Broncoholic
Mankato MN
I just bought my 70 in july it has the170ci and 3 on the tree also
its great to drive.
My only complaint are the air conditioned floors.
W
WADE
Guest
I have a 72 bronco roadster i built 3 years ago it had a colum 3 speed shifter,I switched it to a 3 speed floer shifter and what a world of diff. it is so fun to drive know it took me one day to put it in EASY, and cheep you dont have to by the one for the bronco just by a MR.goodwrench 3 speed shifter and tunnel cover and put it in you have to modify a few things but its simple GOOD LUCK!
Sufferedformula
